Go Back   Community for CG Artists > Critiques and Help > Work in Progress 3D > WIP: Characters
Old 08-30-2008, 03:23 PM   #1 (permalink)
Main Gallery Moderator
iamtravis316's Avatar
first try at z brush
all i have so far is the basic low poly model of the guy and im about to put it in zbrush 3. so if anyone that knows or has used zbrush has any comments, tips, or somthing i need to change on this before putting in zbrush it would be greatly appriciated.
o and I'm not quite done with this yet either I still need to fix the head and put on the hands.
heres a wireframe view....
and I used 3ds Max 2008
and will be using ZBrush 3
Oi Oi Oi
Old 08-30-2008, 06:26 PM   #2 (permalink)
Well one realy important thing is that you should only have 4 sided polys becaus of the way Zbrush subdivide the mesh when you divide it. but its better with 3 sided then 5 sided and more becaus they will give you "Stars" areas imposible to work with in zbrush.
if your not planing to do a retopology in zbrush and are going to animate the character you should gett the topology and loops right befor starting the deformation in zbrush.
Alsow try not to have any open areas like just a deleted poly hole if you understand what i mean :P
Persionaly i like to make a easy uv unwrap of the base mesh so i can use that to make polygroups inside zbrush :)
The Following User Says Thank You to minimus For This Useful Post:
iamtravis316 (08-30-2008)
Old 08-30-2008, 07:59 PM   #3 (permalink)
thanks minimus,
yeah i still have a lot to learn about zbrush lol
and thanks again for the information
Oi Oi Oi
