Go Back   Community for CG Artists > Critiques and Help > Work in Progress 3D > WIP: Architecture
Old 07-11-2005, 11:02 AM   #1 (permalink)
mohamad's Avatar
Rep Power: 6 mohamad is on a distinguished road
Villa Visualize
Hi friends. In this topic I wana explore building of my new project in architecture. It's small villa that designed by Dr. Hamid Mirjani. I hope in this threat I learn more from you and also you enjoy.
Last Image:
Let Start:
- after import cad source to max I start to simulate wall. This level is easy but very important. if you do better this level your render will have better quality.
mohamad is offline   Reply With Quote
Old 07-11-2005, 07:30 PM   #2 (permalink)
mohamad's Avatar
I add secound floor, roof and more objects.
Old 07-12-2005, 04:13 AM   #3 (permalink)
mohamad's Avatar
I finish mine objects and add doors and windows.
Old 07-14-2005, 05:39 AM   #4 (permalink)
mohamad's Avatar
first testing render.
I like get testing render every time from my works with simple (optimizer) material. it help me to find good and bad places in the scene. also I will understand that what places need more details and what places do'n need.
for example you work on the yard plane hard to make more details but in final render much of them will not see.
In "The lord of the ring" film, artists worked hard in the character's foot but just in less the 30 minutes viewers could seen the foots!
Old 07-17-2005, 02:40 PM   #5 (permalink)
mohamad's Avatar
after this level I going to work on doors and windows also working on details. after it you will see attractiver renders! so keep your eye here.
Old 07-22-2005, 07:09 PM   #6 (permalink)
Brave Wolf the Militant
MMOAdude's Avatar
Rep Power: 5 MMOAdude
Send a message via AIM to MMOAdude
This is looking great! Keep it up!
Life is like a box of chocolates, it sucks if you don't like it.
-Middleton
MMOAdude is offline   Reply With Quote
Old 07-23-2005, 08:24 PM   #7 (permalink)
mohamad's Avatar
MMOAdude: Thanks!
I make door and windows and do some details.
After it I add simple optimizer map to objects to get some render test. these render tests help me so much to attend in some details and more other things...
Old 07-23-2005, 08:32 PM   #8 (permalink)
mohamad's Avatar
anoher view...Zoom
(I don't attend to details trully in this project because all render are from far so I will attend more to material and environment)
Old 08-02-2005, 07:18 PM   #9 (permalink)
mohamad's Avatar
Some renders of back yard... attend to chasnges in the left side between this image and next image.
Old 08-02-2005, 07:23 PM   #10 (permalink)
mohamad's Avatar
another image of back yard. I use simply Box modeling to make gable roof and line+edit mesh for making pool.
Old 09-07-2005, 05:06 AM   #11 (permalink)
mohamad's Avatar
after modeling and simple material, I want get final render so this work need final material and light, then camera
and finally render set.
at the first I add material and set light then get some different rendering test that you
can see here.
for light I use one target point with 5.0 multipay, kelvin color by
1800 cd intensity, vray shadow.
all materials are vray material.
Old 09-07-2005, 05:09 AM   #12 (permalink)
mohamad's Avatar
(1) light and render set test...
Old 09-07-2005, 05:12 AM   #13 (permalink)
mohamad's Avatar
(2) light and render set test...
Old 09-07-2005, 05:15 AM   #14 (permalink)
mohamad's Avatar
(3) light and render set...with photoshop effect.
Note: sorry for small and low quality images. as you know I must keep my images size max. 40 kb for forum limitation!
Old 09-07-2005, 05:18 AM   #15 (permalink)
mohamad's Avatar
(4) light and rendering test...
I like to get much render and light test for my projects. after find better result, will try to add nature and work on details for final render.
