| Registered User Join Date: Nov 2005
Rep Power: 0 ![]() | need some help (for total noobie) I'm total beginer in 3ds max (3days now) and i have one BIG problem. I have one good video tutorial whitch explains how to make a model of a car using plane modeling and there is one thing i could not find (see attached photos) how to edit a plane like that:confused: |
Blog Entries: 4 Thanks: 10
Rep Power: 6 ![]() | ye agree. wen you have learnd how to use moste of the tools it will be easyer for us to help you to and probilty you will know how to fix the problem your self. good luck. keep it up.
| Registered User | Yeah, a cars not the best thing to model on your first MAX hours, or even days/weeks/months/years :p I know I didn't try to start modelling a car for about 3 years, but I'm slow at the learning of the modelling process :( To edit it like that, its pretty basic stuff, which is why you should definietly get to learning other types of modelling first. Basically, in the subselection method, since its been turned into an Editable Polygon, they've gone into Edge mode (or poly mode), highlighted the edge (since its flat), and then extruded outwards to create more verteses. You then just keep doing that, correcting in the Sub vertex mode as you go, and edit from different views, while chamfering/smoothing to get the desired results.
__________________ Back here for good :D Check out my latest thread: http://www.3dm3.com/forum/f24/logitech-z-5500-a-14809/ |
