Old 01-18-2004, 07:58 AM   #1 (permalink)
mohamad's Avatar
Rep Power: 10 mohamad is on a distinguished road
what CG?
hi.i want know what of this cards is best:
1- ATI Radeon 9800
2- Geforce FX 5800
3- Geforce FX 5900
and what motherboard is best for best cg?please say model.
thanks.
Making Schwerin Theater
mohamad is offline   Reply With Quote
Old 01-25-2004, 02:42 AM   #2 (permalink)
Lightwave Enthusiast
Rep Power: 9 Matt_D_C
Send a message via AIM to Matt_D_C
If I had to choose between the 3, I would pick the GeForceFX 5900SE. ATI's Raedon is almost as good, but the GeForce has CineFX engine and is capable of 22.4GB/SEC Memory Bandwith, although the Radeon has an impressive antialiasing engine. As for a motherboard, there isn't real a "best" one for CG- It all depends on your processing power, although the MB is just as important. Personally, I would pick a MB that has a higher FSB (Front Side Bus Speed)- This means the it accesses the componets you have faster. Also, I would pick one that uses RIMM as opposed to DDR. Where as DDR-SDRAM (Double Data Rate - Synchronous Dynamic Random Access Memory) is very popular and basically inexpensive, RIMM or RDRAM (Rambus ((Named after the developer)) Dynamic Random Access Memory) is more than twice as fast. The only downside is it MUST be installed in equal pairs. DDR's maxium transfer rate is (amount of memory) @ 500MHz whereas RDRAM is (amount of memory) @ 1066MHz- but all of the MB that support RDRAM a trash, so you probably be better off sticking with DDR. As for the CPU, I recommend something with high pipelined cache, such as P4 2.8GHz. It has 800MHz bus speed and 512KB pipelined burst cache. Sorry to blab, but computer hardware is my line of work, CG is just a hobby (for now!). Here's my recommendations:
GeForceFX 5900SE
Soyo P4I875P Dragon 2 Platinum Edition
Matt_D_C is offline   Reply With Quote
Old 02-01-2004, 05:03 PM   #3 (permalink)
mohamad's Avatar
thanks.:thumbsup:
Old 02-22-2004, 06:36 AM   #4 (permalink)
No problem
Old 03-04-2004, 01:43 PM   #5 (permalink)
Rep Power: 0 deki
ati radeon 9800 pro is the best cg
if you have a money buy this
deki is offline   Reply With Quote
Old 03-13-2004, 01:20 AM   #6 (permalink)
No way- the XFX GeForceFX 5950 Ultra is 256MB DDR, it's got dual 400Mhz RAMDAC, it's core and memory clock are both 475Mhz, and it's memory data rate is 950Mhz. Memory bandwith is 30.4GB/sec, 3.8 BILLION pixels/sec (fill rate), and 356 MILLION verticies/sec. The Radeon's only 128MB, and though it's memory clock is 680Mhz, it's core clock is only 380Mhz- it's unbalanced, and will over heat doing complex 3D animations and/or graphics heavy games.
Old 03-16-2004, 03:43 AM   #7 (permalink)
Rep Power: 0 RusMan
I'd say FX5900 cause GeForce's have better driver support for CG, and Radeon always makes errors.
For motherboard, tell us what CPU you want first.
RusMan is offline   Reply With Quote
Old 03-23-2004, 11:57 AM   #8 (permalink)
eebee's Avatar
Rep Power: 0 eebee
radeon is easily the fastest card, and the newer models have 256 megs of ram......Im running a Radeon 9200 with 256 megs and it works nice, but I wish I had the 9800
eebee is offline   Reply With Quote
Old 03-24-2004, 05:58 AM   #9 (permalink)
death from above
sirpalee's Avatar
Rep Power: 9 sirpalee
Send a message via MSN to sirpalee Send a message via Yahoo to sirpalee Send a message via Skype™ to sirpalee
Hi, i think, radeon is better for 3dsmax, but is you have money, just buy Quadro fx, that is the best, but you can't play with it:(
There is no fate.
Only possibilities of virtually unlimited random events.
Some have greater chance, some have smaller.
If we are good, we can change the chances, to get the derised flow of events.
sirpalee is offline   Reply With Quote
Old 09-16-2004, 01:45 PM   #10 (permalink)
Jedi Animator
XPilot's Avatar
Rep Power: 8 XPilot
Send a message via MSN to XPilot Send a message via Yahoo to XPilot
My GeForce 5900 FX / 256 MB/Ram works fine ! and I don't see too much difference between the way they render ! I mean I uninstalled it ang got in my old GeForce 2 MX 400 and still I got the same result :( Dunno why, but I think its all based on the ram you're having :P
XPilot is offline   Reply With Quote
Old 09-24-2004, 05:56 PM   #11 (permalink)
Sylvester's Avatar
Rep Power: 8 Sylvester
Send a message via Yahoo to Sylvester
I think the best is GeForceFX 5900 ULTRA or ATI Radeon 9800 XT ...
the GeForceFX 5900Se is not so good because is equivalent with GeForceFX 5900 Xt and YOU MUST BE CARFULLY
At the Ati card the "XT" card si best then no Xt card for example Ati Radeon 9800XT si BEST then Ati Radeon 9800
At the Nvidia car the "XT" card is worse then no XT card for example GeForceFX 5900XT is worse then GeForceFX 5900
and at nvidia the "ULTRA" IS THE BEST :)
see the http://www.tomshardware.com/ is the best site in hardware test and they have a graphic card test hope is it stil on they pages ... if you want I will send you the test pics to you because i have save it on my pc.
BUT this cards and this tests are for games and "sirpalee" have right the BEST card for CG are Nvidia Quadro fx and Ati FireGL
here is the link of the article and test about that 2 Graphic Cards on tomshardware site
http://graphics.tomshardware.com/gra...323/index.html
and here is the link direct to Article and TEST about that 2 cards and 3D Studio Max 4.2.6 ...SO :)
http://graphics.tomshardware.com/gra...00-x2t-09.html
GOOD LUK hope this help.
Sylvester is offline   Reply With Quote
Old 09-27-2004, 03:14 PM   #12 (permalink)
The Lugerer's Avatar
Rep Power: 0 The Lugerer is on a distinguished road
ok well the best graphics card out is the ATI Radeon X800XT, but at about $600 (US) it's out of most people's price range. i have a ATI Radeon 9800XT (256MB) which is about 350 US dollars, and i love it. the thing i don't like about the nVidia cards is most (if not all?) take up two PCI slots instead of one...and if you have a 6.1 channel sound card, firewire card, USB card, dual LAN, and whatever else gamers like me have, you don't usually have extra PCI slots to use :p
Got Lugered?
The Lugerer is offline   Reply With Quote
