Old 03-27-2005, 01:26 PM   #1 (permalink)
metalRahul's Avatar
Rep Power: 9 metalRahul
Send a message via Yahoo to metalRahul
hello just need some info
hi just wanna know with new SLI technology in motherboards
what all benifits that 3d and 2d designers will have :type:
hope somebody will hit back :buttrock:
metalRahul is offline   Reply With Quote
Old 04-04-2005, 11:26 AM   #2 (permalink)
Rep Power: 0 falcoss is on a distinguished road
ok well i will share what i know of SLI basicly it used 2 cards and doubles the performance and speed that they can work at giv/take. this is probably aimed at the gamer with too much cash to spend or who want bragging rights. this only works with PCI-E and needs special mo-board and uses more power (2 physical cards). im not too sure what the implications for 2d/3d designers but i imagin that any task which used the graphics card extencivly will be able to draw more processing power, much the same way that upgrading your graphics card would do.
falcoss is offline   Reply With Quote
Old 04-01-2006, 11:21 AM   #3 (permalink)
Rep Power: 0 baba
hi i want to know about digital cams
baba is offline   Reply With Quote
Old 04-01-2006, 11:21 AM   #4 (permalink)
Rep Power: 0 baba
fddfgdfg d dfg
Old 04-01-2006, 03:00 PM   #5 (permalink)
Kazus's Avatar
Rep Power: 7 Kazus is on a distinguished road
What do you want to know about it?
Θ ςσς Ξρςΰοΰ οξνερλξ......
Auto-3d(Russian resource)
Kazus is offline   Reply With Quote
Old 10-27-2006, 07:51 AM   #6 (permalink)
Rep Power: 0 mqasim20012002 is on a distinguished road
Send a message via Yahoo to mqasim20012002
Hi, [green]I cant say.[/green]
mqasim20012002 is offline   Reply With Quote
Old 09-01-2008, 08:10 AM   #7 (permalink)
Rep Power: 0 sam786420 is on a distinguished road
Hello! My name is Sam Adams. I want to know the best buy price of the computer with it's latest configuration along with LCD monitor and Printer of H.P.
Sam
4th Dimension Private Limited is a BPO
4th Dimension
sam786420 is offline   Reply With Quote
Old 09-02-2008, 02:51 AM   #8 (permalink)
Rep Power: 0 kelvin123789 is on a distinguished road
Need some help
Hi I want to buy a PC but I am confused on which one to buy.
I want a PC with a good processing speed and with good memory.
Can anyone suggest me a good PC to buy with the latest features.
Kelvin
4th Dimension
kelvin123789 is offline   Reply With Quote
Old 09-04-2008, 08:01 AM   #9 (permalink)
Hi, I am Kelvin Martin.
If you want to buy a digital camera then I would tell you about the best
camera that I have also used.
Its the Sony Alpha DSLR-A700
Price (body only)
• $1400 [check]
Body material * Magnesium Alloy chassis, high grade plastic exterior
Sensor * • 23.5 x 15.6 mm CMOS sensor 'Exmor'
• RGB Color Filter Array
• Built-in fixed low-pass filter
• 13.05 million total pixels
• 12.25 million effective pixels
• On-chip Column A/D Conversion & NR
Image sizes *
• 4288 x 2856 (L RAW )
• 4272 x 2848 (L)
• 3104 x 2064 (M)
• 2128 x 1424 (S)
• 4272 x 2400 (L) 16:9
• 2128 x 1200 (S) 16:9
File qualities / formats * • RAW (.ARW 2.0)
• Compressed or uncompressed RAW option
• RAW + JPEG Fine
• JPEG Extra Fine
• JPEG Fine
• JPEG Standard
Dust reduction • Static-resistant anti-dust coating
• CCD-shift dust reduction mechanism
Lenses • Sony Alpha lenses
(also compatible with Minolta A-type bayonet mount lenses)
FOV crop 1.5x
Super SteadyShot • CCD-Shift 'Super SteadyShot' system
• Five level LED shake indicator in viewfinder
• Claimed equivalent to 2.5 – 4 steps in shutter speed *
Auto Focus * • TTL CCD line sensors (11-points, 10 lines with center dual cross sensor)
• EV 0 to 18 (ISO 100) detection range
• Predictive focus control for moving subjects
AF area selection
• Wide AF area
• Spot AF area (center)
• Focus area selection (any of 11)
Focus modes • Single-shot AF
• Direct Manual Focus
• Continuous AF
• Automatic AF
• Manual focus
AF assist
illuminator * • Yes (built-in LED lamp)
• Range approx 1m - 7m
Eye-start AF Yes, selectable from menu (optionally with grip sensor trigger*)
Shooting modes
• Auto
• Programmed AE (with shift)
• Aperture priority AE
• Shutter priority AE
• Manual
• MR (memory recall) / Custom
• Scene modes (below)
Scene modes • Portrait
• Landscape
• Macro
• Sports Action
• Sunset
• Night view/portrait
Sensitivity
• Auto (200 - 1600) - upper/lower limit selectable *
• ISO 100
• ISO 200
• ISO 400
• ISO 800
• ISO 1600
• Up to ISO 6400 (expanded range) *
Metering modes • Multi-segment (40 segment Honeycomb pattern)
• Center-weighted
• Spot
Metering range • EV 0 to 20 (Multi-segment / Center-weighted) *
• EV 2 to 20 (Spot metering) *
(at ISO 100 with F1.4 lens)
AE Lock • AEL button (customizable)
• Half-press shutter release
AE Bracketing • Single or continuous bracketing
• 3 or 5 frames
• 0.3, 0.5 or 0.7 EV steps *
Exposure compen. • -3.0 to +3.0 EV *
• 0.3 or 0.5 EV steps *
Shutter Electronically-controlled, vertical-traverse, focal-plane Shutter
Shutter Speed * • 30 to 1/8000 sec
• Bulb
Flash X-sync * • 1/250 sec
• 1/200 sec (with Super SteadyShot on)
Aperture values Depends on lens, 0.3 EV steps
DOF preview Yes, dedicated button
White balance
• Auto
• Daylight
• Shade
• Cloudy
• Tungsten
• Fluorescent
• Flash
• Color temperature (2500 - 9900 K)
• Manual (Custom) - 3 memories *
White balance fine tuning • Auto (none)
• Preset WB: -3 to +3
• Fluorescent WB: -2 to +4
• Color temperature WB: G9 to M9 (Magenta to Green)
White balance bracketing • 3 frames
• Hi or Lo steps
Dynamic range optimizer
• Off
• Standard
• Advanced Auto *
• Advanced
• DRO advanced bracketing (3 frames, High/Low selectable) *
Color space • sRGB
• Adobe RGB
Color modes • Standard
• Vivid
• Neutral *
• Clear *
• Deep *
• Light *
• Portrait
• Landscape
• Sunset
• Night view
• Autumn Leaves *
• B&W
• Sepia *
• Adobe RGB
Image parameters * • Contrast (-3 to +3)
• Saturation (-3 to +3)
• Sharpness (-3 to +3)
• Zone Matching (-1 to +2 steps)
• Brightness (-3 to +3 steps)
(Available in all color modes)
Noise reduction * • Long exposure for exposures longer than 1 second
• High ISO NR High/Normal/Low at ISO 1600 or higher
• User controllable: On / Off
Viewfinder *
• Eye-level fixed optical glass pentaprism
• Spherical Acute Matte focusing screen (interchangeable)
• Magnification approx. 0.9x
• 95% frame coverage
• Dioptric adjustment (-3 to +1.0)
• Eye-relief 25 mm from eyepiece, 21 mm from frame
• Eyepiece cup removable
• Viewfinder info bar
LCD monitor * • 3.0 " 'Xtra Fine' TFT LCD
• 920,000 pixels (640 x 480 x 3 (RGB))
• 270 ppi
• Anti-reflective coating
Flash • Built-in pop-up flash (manual release)
• Metering: ADI, Pre-flash TTL, Manual flash control
• Guide number 12 (ISO 100/m)
• Angle of coverage 24 mm (35 mm equiv.)
• Flash sync 1/250 sec, 1/200 sec (SteadyShot on) *
Flash modes
• Auto
• Fill Flash
• Rear Sync
• Slow sync
• Manual Flash
• Red-eye Reduction (pre-flash)
• Wireless/Remote Off-camera Flash
• High Speed Sync.
Flash compensation * -3.0 to +3.0 EV in 0.3 or 0.5 EV steps
External flash (optional) • Sony HVL-F56M (guide no. 56)
• Sony HVL-F36M (guide no. 36)
• Macro Twin Flash Kit HVL-MT24AM
• Ring Light HVL-RLAM
• Off camera flash shoe FA-CS1 AM
Drive modes • Single-frame
• Continuous (H/L selectable) *
• Self-timer (10 or 2 sec)
• Continuous bracket
• Single-frame bracket
• White balance bracket
• DRO bracket *
Continuous
shooting * • H: Approx 5fps max
• L: Approx 3fps max
• RAW: Up to 18 frames
• cRAW (compressed): Up to 25 frames
• RAW+JPEG: Up to 12 frames
• JPEG (XFINE): Up to 16 frames
• JPEG (STD/FINE): Unlimited (to card capacity)
Self-timer
• 10 sec
• 2 sec
• Mirror up function (optional)*
Orientation sensor Yes, for shooting, playback and control panel display
Connectivity * • USB 2.0 Hi-Speed (mass storage, Multi-LUN or PTP)
• Video out (NTSC or PAL)
• HDMI type C mini jack
• DC-IN
• Remote terminal
• PC control (with supplied software)
Remote control * • Wired: with optional RM-S1AM or RM-L1AM
• Wireless: with included remote control
Video out • AV (Selectable NTSC or PAL)
• HDMI (1920 x 1080i, 1280 x 720p, 720 x 580p, 720 x 576p)
• 'PhotoTV' HD settings applied with BRAVIA.
Storage * • Compact Flash Type I/II
• Memory Stick Duo / Pro Duo
• Supports FAT12 / FAT16 / FAT32
Power * • NP-FM500H Lithium-Ion rechargeable battery (1650 mAh)
• Battery charger included
• Optional AC adapter
• Batter life Approx 650 shots (CIPA standard)
Vertical grip * • Vertical Grip VG-C70AM
• One or Two NP-FM500H batteries with auto switchover for power (additional battery is optional).
Dimensions 141.7 x 104.8 x 79.7 mm (5.6 x 4.25 x 3.25 in)
Weight (body) • No battery: 690 g (1.5 lb)
• With battery: 768 g (1.7 lb)
Kelvin
4th Dimension
Old 09-28-2011, 04:14 AM   #10 (permalink)
Rep Power: 0 Guns&Roses is on a distinguished road
kelvin123789, you are so great~!
Guns&Roses is offline   Reply With Quote
