Old 01-14-2010, 01:42 PM   #1 (permalink)
3DM3 Administrator
VIDEO TUTORIAL: New Morph Technology in Zbrush and More
This will show you how to morph two completely different objects into one this will also show you how to optimize your geometry with two completely different objects and both will have the same amount of polygons to be morphed this will show you how to have three or more morph from one object or if you're just trying to find a fast way to get new models on the market and if you are running out of ideas morph will give your imagination new ideas.
Read more >>
Old 01-23-2010, 01:23 AM   #2 (permalink)
WilD-AL's Avatar
Rep Power: 3 WilD-AL is on a distinguished road
hey... very nice tutorial..
what you have done with sphere with \\\\\\\ " projekt all \\\\\\\ " I always do with retopo...
however, also a good method
WilD-AL is offline   Reply With Quote
Old 01-23-2010, 12:49 PM   #3 (permalink)
Rep Power: 0 E-Zbrush is on a distinguished road
Exclusive Publisher Exclusive Publisher
thank you i all so have another one on the front page called Reconstruct Model using zbrush.
zbrush has 2 kinds of sphere
the default poly sphere and the 3D Sphere
now if you want to lower the poly sphere like the one i had in the video just go to Tools>Geometry tab> Del lower
then go down a bit to> Reconstruct subdivision and click it as many times as you want
and you will see the sphere will turn into a cube when it stops this sphere is based on a cube
which is very good for modeling heads .
the default Sphere a while back had pole holes on the top and bottom of the mesh
and if you subdivided it a lot the hole's will become visible
and if you looked at the sphere in wire frame mode it looked like the top and bottom were triangles but they were not the sphere were all quads but all the top and bottom points were all bunched up to 1 center spot.
here is a preview tunable of the video above using morph blip.tv/file/3083947
E-Zbrush is offline   Reply With Quote
Tags
morph, technology, tutorial, video, zbrush
