Old 01-14-2004, 04:37 PM   #1 (permalink)
Rep Power: 0 fiuOY
removing chroma key from a picture
hello all.
Brand new to this forum. Hope I can get some help.
looking for the best way to remove the green screen from the pic below using photoshop 7. I have tried different methods but all seem to yield similar results.
They work pretty good but when put against a black background it doesn't look too good.
Here's the pic I'm trying to work with.
p.s., I know the pic doesn't have the best quality, but that's the point. If I find a method that can work on this picture, then it will work wonders with a welll taken picture.
Thanks in advance.
fiuOY is offline   Reply With Quote
Old 01-14-2004, 04:38 PM   #2 (permalink)
Rep Power: 0 fiuOY
here's the pic..sorry
Old 01-15-2004, 11:00 AM   #3 (permalink)
Geekiness Extremeous
DVeditor's Avatar
Rep Power: 6 DVeditor
Well one way you can do it is by using the "extract" function, another is to manually create a mask for the subject, and still a third would be to use a plugin to extract a color key. What you use will depend on the source image. In this case I see very little spill on the subject and no harsh shadows so it should be fairly easy! Hope this helps!
Later.
- CK Hicks -
My Website
deviantART Gallery
DVeditor is offline   Reply With Quote
Old 01-15-2004, 11:29 AM   #4 (permalink)
Rep Power: 0 fiuOY
well a mask would work fine, but I'll probably have to 30 of these. But the plug in sounds good. Do you know of any for photoshop 7.
thanks in advace
Old 01-18-2004, 09:31 AM   #5 (permalink)
DVeditor's Avatar
Sure. You can use ultimatte for starters, but I don't think it's a cheap plugin. If you are going to be doing a lot of them then the extract function is probably going to be your best bet. Hope this helps.
Later.
- CK Hicks -
My Website
deviantART Gallery
« Coke Can | lights »
