Old 04-07-2008, 09:35 PM   #1 (permalink)
Rep Power: 0 oellas is on a distinguished road
3D Scene Modeling Competition
oellas clock tutorial
Hi people, in this tutorial I will show you a few tips to create a clock in 3d max and render it with Fryrender. Then I will show you how to apply fry materials and how to make the light setup. Finally, I will show you how to work with the tonemapping and layer blending controls.
REFERENCE IMAGES:
MODELING:
Start with a cylinder and change the number of slices, convert to Editable Poly and create the three outer parts
During this process we will use symmetry and meshsmooth modifiers to see the mesh result
Before we start with the interior, we will link the three green objects with a helper to control their position, for the interior part we will do the same
The numbers are a text spline with an extrude modifier, and then an array over the clock's surface. The inner gears have been made with splines and a bevel modifier
To make the chain, we will prepare its parts individually. Use spline IK Solver to link the hoops of the chain, and obtain a custom chain the path
MATERIALS:
These are all the material used in the scene.
LIGHTING:
The light setup is very simple. With the same material emitter, two planes and other emitter objects inside the clock we will be able to obtain very diferents results in layer blending afterwards. We will apply a fryrender object modifier to each light source, in order to control them via Layer Blending.To illuminate the scene, we will use an environment map too.
RENDER:
During or after the render process we may adjust the emitters detached into layers with the fryrender object modifier, using Layer Blending. We can change the intensity of every emitter and/or change its RGB hue according to our criterion. Finally add and adjust vignetting and glare effects
SEE IN: oellas
oellas is offline   Reply With Quote
The Following User Says Thank You to oellas For This Useful Post:
motorider420 (07-30-2008)
Old 04-09-2008, 07:00 PM   #2 (permalink)
Awsom absolutley stunning :) great work, and thanks for taking your time making this.
you could maybe have explaind more about the modeling part. sounds a bitt tricky.
Old 07-20-2008, 04:24 PM   #3 (permalink)
Rep Power: 0 india is on a distinguished road
excellent work.,. but the tutorial sucked. it was almost like you was talking to yourself..it explained almost nothing
india is offline   Reply With Quote
Old 02-10-2010, 07:26 PM   #4 (permalink)
Rep Power: 0 tyson_nicky is on a distinguished road
It would be better if you went into much, much higher detail for people like myself who have no idea on how to use this plugin for max.
you presume we all are experts like you in Fryrender?
tyson_nicky is offline   Reply With Quote
You Rated this Thread:
