Old 02-27-2008, 09:35 PM   #1 (permalink)
tensun's Avatar
Rep Power: 0 tensun is on a distinguished road
3dsmax Video Tip VRay Material Dirt
I find a new Vray shader recently, the “vraydirt”(it also known as a AO shader in Vray) shader. And I make a render test with share some tips here, hope it helps.
Video Preview (youtube)
Full Version Download (tensun3d.com)
This is the result before applying “vraydirt” shader, it looks shadow-less and weight-less.
This is the result after applying “vraydirt” shader, it looks more real form previous one and rendering very fast. It looks like a little “3S” effects, but I’m still hard to make a good 3S control from Vray.
The final results, I applying reflective materials and adjusting glossiness values. The rendering speed is slowing down however with a very well result, we can try more values between the speed and quality.
more 3dsmax tutorials here
www.tensun3d.com
tensun is offline   Reply With Quote
Old 02-28-2008, 03:42 PM   #2 (permalink)
oh! sweet...i dint know it could be used to that to.
i always have problem sowing hall the details inn my work becaus the edges and such not get dark enought :) thanks for the tips, i check out the Vray dirt
Old 03-01-2008, 03:24 AM   #3 (permalink)
tensun's Avatar
You're welcome.
www.tensun3d.com
Old 03-14-2008, 12:49 PM   #4 (permalink)
Rep Power: 0 Norstu is on a distinguished road
Thanks Tensun! :-) Thank you very much for making tutorials. Each one of your tutorials have helped me tremendously.
Norstu is offline   Reply With Quote
