Old 01-22-2008, 05:13 PM   #1 (permalink)
3DM3 Administrator
3DM3 Tutorial: Setup car rendering studio with V-ray
This tutorial will teach you to create softly illuminated room environment as in a real auto studio very fast. Quick light positioning and auto paint material setup.
Read more >>
Old 01-22-2008, 07:21 PM   #2 (permalink)
Rep Power: 0 byousif is on a distinguished road
hi! thanks for the tutorial but the link to the file is dead. any chance of fixing it? much appreciated.
byousif is offline   Reply With Quote
Old 01-23-2008, 10:10 AM   #3 (permalink)
Rep Power: 0 majoron is on a distinguished road
link is dead.
majoron is offline   Reply With Quote
Old 01-23-2008, 04:57 PM   #4 (permalink)
Rep Power: 0 Nessie
everything works here
Nessie is offline   Reply With Quote
Old 01-23-2008, 05:56 PM   #5 (permalink)
3DM3 Administrator
Link works great. If not, use this http://www.3dm3.com/tutorials/vray_r...udioSphere.zip
Old 01-25-2008, 08:31 PM   #6 (permalink)
hi stryker! thanks for fixing it. much appreciated. take care.
Old 02-03-2008, 07:17 PM   #7 (permalink)
be_fast's Avatar
Rep Power: 7 be_fast is on a distinguished road
Oh, so many of you, folks are the same.........I made this tutorial to show how YOU CAN MAKE IT YOURSELF. Step by step! Just TRY!
Downloading ready setuped studio is not best way....I am not sure i was right with posting ready scene =(
be_fast is offline   Reply With Quote
Old 02-22-2008, 03:21 AM   #8 (permalink)
Rep Power: 0 hosam is on a distinguished road
Thank you very much be fast, this tutorial is simple, cleare and the best one i have seen befor..
hosam is offline   Reply With Quote
Old 02-22-2008, 04:14 AM   #9 (permalink)
be_fast's Avatar
You are welcome, Hosam
Old 03-10-2008, 03:56 PM   #10 (permalink)
Rep Power: 0 Mr-914 is on a distinguished road
I'm trying to recreate your 3DM studio in Maya. I've made some good progress so far, but I'm still missing a couple of things. I hope your knowledge of 3DM can help me in Maya. See best render below.
1. I'm seeing the lit surfaces a lot in my mirrored ball. Could it be because of the shader I'm using on my walls? Right now I'm using blinn, although I used a lambert before with the same results.
2. Should I have all lights emiting both specular and diffuse?
3. I can't seem to get the highlight light to work. It's in the file for the image below, but it only seems to add an ambient light to the scene. I haven't played with that much, but if you have an idea, let me know!
Thanks!
3DM3 Tutorial: Setup car rendering studio with V-ray-studio.jpg
Mr-914 is offline   Reply With Quote
Old 03-11-2008, 11:08 AM   #11 (permalink)
be_fast's Avatar
I am using V-ray (it means V-ray lights, V-ray materilas, V-ray GI). If you want to get similar result in maya it is the question of your imagination flexibility. BUT I don`t know Maya GI/Materials/Lights properties and cant tell you wat to do. The only thing I know - more Experiments - better result.
Old 03-11-2008, 05:13 PM   #12 (permalink)
I just need to know what looks wrong. V ray or Maya, the basics of indirect illumination are the same.
I made some progress today. I changed the highlight from an area light to a spot light with barn doors partly closed. Maya doesn't have a linear light. This gives me the kind of highlight in the tutorial. Another thing I found is that my spot illuminating the back wall was too large and bright. This is flooding out the shadows of my objects. I still need to tweak that. Otherwise, I'm almost there.
3DM3 Tutorial: Setup car rendering studio with V-ray-studio2.jpg
Old 03-11-2008, 07:58 PM   #13 (permalink)
be_fast's Avatar
yes, much better already
Old 03-12-2008, 11:45 AM   #14 (permalink)
I'm happy now. I did a few things. Mainly, adjusted the area lights to have show the form better. I also put a slight penumbra angle (1 degree I think) on the spot light giving the linear highlight. This spread it out a little. I think it looks a little more real that way. Also, I adjusted the spot light that is lighting the background. I increased its spread and penumbra in order to have a more uniform lighting.
3DM3 Tutorial: Setup car rendering studio with V-ray-studio3.jpg
Old 03-12-2008, 04:35 PM   #15 (permalink)
be_fast's Avatar
Nice but overlighten a little. But if you like it it`s your business. I`d advice to decrease intensity of back ground light. This way you will get the effect of illuminating behind the sphere.
Good luck, keep working
You Rated this Thread:
