Old 04-29-2011, 06:50 PM   #1 (permalink)
Rep Power: 0 obliviboy is on a distinguished road
Subdivision Reversion
Subdivision Reversion will recreate the subdivision levels of an already subdivided mesh with 100% precision. It works with only 3ds Max 2011 and 3ds max 2012 (x86 and x64).
Here are some of the benefits you get:
•If a 3d model you buy online has it’s modifier stack collapsed it is almost useless, you can’t edit, unwrap, rig it, but with Subdivision Reversion you can reconstruct the first subdivision level and then do all the above.
•If in your production pipeline you need at some point to collapse the model with Subdivision Reversion you can get the subdivisions back later
•When you apply a turbosmooth modifier to a reconstructed subdivision level you will get exactly the same mesh as the original
Get it from here subdivisionreversion . zzl . org
(remove the spaces from the link)
obliviboy is offline   Reply With Quote
Tags
3ds, max, reversion, subdivision, turbosmooth
