| Registered User Join Date: Jun 2009
Rep Power: 0 ![]() | MachStudio Pro Adds 3ds Max Exporter, Animatable Fog, and Materials Library MachStudio Pro is stand-alone, visualization and rendering software that lets 3D *artists create and manipulate lights, materials, and HDR cameras in a real-time, non-linear workflow environment to achieve film quality results. It harnesses multi-threaded GPU computing to change the equation of time vs. quality. Frames that normally take 20 to 40 minutes each to render can be rendered in seconds at comparable quality in MachStudio Pro. Processes which normally would be separated into specialized tasks in production, or off-loaded to render farms, *are instead possible in a concise, creative workflow. The new MachStudio Pro v1.0.2.10 adds many new features including: Exporter for 3DS Max 2009 With this addition there are now dedicated exporters for Maya 8.5, 2008, 2009 and Max 9 and 2009 (Max 2008 and 2010 as well as 64-bit versions coming soon). A dedicated exporter makes it fast and easy to export geometry, animation, and cameras. Importantly, if you update the animation file in Maya or Max, simply open it again, and it will automatically update in MachStudio Pro. You can even update just a sequence of animation frames and plug-them right into the MachStudio Pro scene. High-quality Materials Library 107 unique materials that you can apply to any material node (e.g. fabric, glass, paper, wood, marble, etc.). Artists can tweak and adjust as they would any shader. Animatable fog This allows the appearance of a fog effect to change as the eye-point moves in relation to an image. Or artists can create things like the effect of rising ground fog layers in the trees above a lakeshore. Enhanced shader control Blinn and Blinn Reflective shaders now have a Specular Power slider, Blinn, Phong, Phong w/Bump and SubSurfaceScatter shaders have Angle slider to use with reflection maps, Car Paint shader now has Opacity Texture file option, etc. Diffuse and Specular render passes Just as you can render out DOF, depth maps, glows, AO, etc. passes at HD or film resolution for later compositing, you can now render out the diffuse and specular passes. Unicode support Unicode enables Asian language support in MachStudio Pro.* - Information about MachStudio Pro on the StudioGPU website - Samples of projects lit and rendered in MachStudio Pro can be seen in the showcase |
