| Forum Moderator ![]() Join Date: Jan 2008
Rep Power: 2 ![]() | Forum: CG News Posted By: AtelierS Post Time: 04-24-2008 at 10:31 AM Text: Atelier Software has released Fanurio version 1.10, a Windows and Mac OS X time tracking and billing application designed for freelancers. With Fanurio you can easily organize your work, track time and create invoices. In order to keep track of client work, you can create a project for each client. Then you can record time and expenses. Work can be marked as billable or non-billable using a flat rate or an hourly rate. While working for a client, you can create partial invoices for a project. But if you are working on more than one project for the same client then you can create an invoice for all of them. Invoices can be generated to a text or html file using an invoice template The application can be accessed from the Windows tray bar and it detects idle time. Fanurio can export its data to a CSV or Excel file so that you can easily import it in other applications like Microsoft Excel or OpenOffice.org Calc. Here is a list with all the important changes of this version: * Runs on Linux * Added smart timing to track time easier * Added more timer actions * Can create similar projects * Invoices are exported using UTF-8 character encoding * Many other improvements and bug fixes Fanurio costs $39 and it is available from http://www.fanuriotimetracking.com . You can download a fully-functional trial version from http://www.fanuriotimetracking.com/download.html . More...
__________________ www.3dexport.com - 3D Models Store |
