Old 06-28-2009, 01:20 PM   #1 (permalink)
Credits: 38,852
Rep Power: 6 NewsMaker is on a distinguished road
Lightbulb cmiVFX Launches Blender Organic 3D Modeling Techniques
Forum: CG News
Posted By: sebastian-koenig
Post Time: 06-28-2009 at 04:02 PM
Text:
Watch High Definition Training Videos For The Visual Effects Industry Instantly From Anywhere In The World.
Princeton, NJ., June 28th, 2009 — cmiVFX | cmiStudios launches a brand new video for the open source project called Blender. This application has set the bar for open source development everywhere. Its robust set of tools were created by the world, for the world. Blenders recent builds have put it in the upper echelon of the animation production pipeline. It can be used to do everything from Painting to Compositing and everything in between. This video release focuses on true, tried and tested modeling techniques that can be used for production level animation. Since Blender is free, we suggest that everyone takes a look at this video. it will NOT disappoint! When it comes to high end CG and VFX training, there is only once choice... cmiVFX. This video is available today at the cmiVFX store. cmiVFX Video Player Online Store http://cmivfx.com/store/Browse.aspx?Category=6
Product Announcements — Blender "Organic 3D Modeling Techniques"
http://cmivfx.com/Blender3D_Trainin...es/default.aspx
Blender in production process and setup:
Take your Blender skills to the next level! This video will take you through the process of creating a high-detail model of a mammoth in Blender. You will learn how to make efficient use of Blender’s modeling tools, including not only box-modeling and poly-by-poly-modeling, but also how to use the modifier stack and how to use multi-resolution, sculpting and the re topology-tools.
Foundation Workflow:
Setup background-images to have your reference-pictures right in the viewport. Use the grease-pencil to trace images to create a better outline. Paint in 3D-space, use layers and define custom-colors to create flexible and even animatable modeling-references.
Mesh Modeling:
Learn how to efficiently use Blender’s mesh-modeling-tools. See how the knife-tool works and how you can easily control the edge-flow with the knife in combination with loop-cuts. Rotate edges and faces to quickly adjust your topology.
Modifiers Interoperability:
One of the many nice features in Blender is the modifier-stack. By combining multiple modifiers like for example mirror, array, mesh deform, smooth and subsurf-modifier you can create complex shapes out of just a few vertices.
Weight Mapping For Manipulation:
Use vertex groups to control the area that should be affected by a modifier and use weight-painting to have an intuitive way of controlling the influence of that vertex-group. All that can be done easily and in a non-destructive workflow that let’s you make changes and corrections until you are satisfied and, if needed, let’s you finally apply the modifiers and make these changes “real”.
Sculpting Tools That Rival Expensive Commercial Solutions:
Another great feature in Blender are the sculpting-tools. Especially for organic modeling there couldn’t be an easier and more intuitive way of working than just paint volumes onto your mesh, pinch areas, smooth details and so on without having to care about vertices. Use multi-resolution to interactively subdivide your mesh and work on the different levels. Rough out the volumes on lower resolution levels and fine tune your mesh on high res-levels. Customize your brush with procedural textures, or create your own brushes by using blenders built in image editor.
Retopology:
Sculpting often leads to high-density meshes that are great for stills or texture-baking but completely unusable for animation. The solution for that is to rebuild the geometry by using Blender’s retopo-tools. Simply paint your vertices and edge-loops onto the mesh according to the topology and let Blender take care of the rest.
Shrink Wrapping:
Combine the retopology tools with the shrinkwrap-modifier and paint props like cloths, coat or armor right onto the mesh while using an offset that will prevent your meshes from intersecting. Create perfectly smooth surfaces with the subdivision-surface-modifier and use the crease-tool end edge-split-modifier to create sharp edges.
About the Author:
Sebastian K?nig is a german 3D-artist who is working as a freelancer and CG-instructor for several years now. During his studies for Education of Art he discovered the joy of modeling and creating 3D-Animations with Blender and hasn’t stopped ever since. Being a passionate Blender-User he has been teaching Blender at the University of Art and Design Halle/Germany and is also giving online-classes. He has been working for various studios and companies as a 3D-Artist and freelancer. During the dozens of projects and jobs he completed with Blender he got a profound knowledge of almost every aspect of this great Open-Source 3D-application.
About cmiVFX
cmiVFX is the leader in High Definition Video Training for the Visual Effects Community. To test drive the new cmiVFX TVOD © system, visit http://www.cmivfx.com/cmi_vod.html For additional information about cmiVFX, visit www.cmivfx.com.
© 2009 cmiVFX | cmiStudios. All rights reserved.
Source
www.3dexport.com - 3D Models Store
