Old 08-03-2009, 03:20 PM   #1 (permalink)
Super Member
Lightbulb Autodesk annouces Mudbox 2010
Forum: CG News
Posted By: egarreau
Post Time: 08-03-2009 at 03:54 PM
Text:
Today at SIGGRAPH, Autodesk launched Mudbox 2010.
The feature highlights of this release are:
- FBX support: import and export meshes, object names, cameras, texture maps, shader settings with 3ds Max, Maya and Softimage.
- PSD file support: export your Mudbox 3D View as PSD, at a user defined screen resolution for image editing, color correction, pattern creation, text or decals. Auto re-project saved changes inside Mudbox 2010, across multiple objects and multiple high res texture maps in your scene. Also new to this release, Mudbox 2010 2D texture layers can be exported to PSD allowing you to paint in a flattened texture space. Once 2D edits have been made, the Mudbox layer can be updated to receive the changes.
- Render from viewport: render high resolution images directly from the viewport for presentation.
-New viewport filters: preview the appearance of your model when rendered in another application using the non-photorealistic render filter, the normal map filter, and other new filters.
- New brushes: try the clone brush, dry brush and improved wax brush
- SDK: customize Mudbox using the new C++ application programming interface (API) to integrate it into your pipelines.
- Painting Tools & Workflows Enhancements
If you are at Siggraph, don't miss Wayne Robson's Master Class: Advanced Autodesk Mudbox tips & workflows.
Autodesk anticipates that Mudbox 2010 will be available in August 2009. The 32-bit version of Mudbox 2010 will be supported on the Windows Vista Business (SP1), Windows XP Professional (SP2) and Apple Mac OS X 10.5.7 operating systems. The 64-bit version of Mudbox 2010 will be supported on the Windows Vista Business (SP1) and Windows XP x64 Edition (SP2) operating systems.
More info on :
www.autodesk.com/mudbox
http://www.the-area.com/blogs/davec/
Source
