Old 02-03-2004, 07:19 AM   #1 (permalink)
Rep Power: 0 Wheels
Welding problems
hi i am using 3ds max 6.0 and i am spline modelling an audi tt, however i am having problems when sometimes to spline points wont weld together, even when the distance is set to high numbers like 20(extreme), has anyone else had this problem?
also in max 6 the program keeps closing on me while im working, and although it 'tries' to make a backup, i can never find it
Wheels is offline   Reply With Quote
Old 02-03-2004, 10:36 AM   #2 (permalink)
NAD
Rep Power: 0 NAD
Sounds familiar
I think you're getting the same problem as me, check my Spline Vertices post.
NAD is offline   Reply With Quote
Old 02-03-2004, 05:23 PM   #3 (permalink)
M0DERATOR
Rep Power: 6 the_solidshadow
the backup should be in "C:\3dsmax6\autoback" or in the "autoback" folder in your max6 root folder
the_solidshadow is offline   Reply With Quote
Old 02-04-2004, 03:19 PM   #4 (permalink)
Sir_Vulcan's Avatar
Rep Power: 6 Sir_Vulcan
Send a message via AIM to Sir_Vulcan
you can only weld spline end points. for the intersecting points inbetween you can just fuse them together. So what that means is only 2 vertices can be welded at any point and if theres more then there just fused or in the same spot. theres an option in Max that you can turn on so when you click on one vertex it selects the ones that are fused to it. Ill try to find that option for you
Sir_Vulcan is offline   Reply With Quote
