| Hallowed Devil | Transparent Background....quite dnt understand dat. Cn ye plz gv n example ov Transparent Background.....i mayb able to help. btw, if ye want some object to be transparent...or precisely, low opacity, den select the object n press ALT X. it turns less opaque :) Cheers!
| Registered User | Thanks Shashanks, but not transparent objects I want. When you render a scene, the bg is black, or another color. So that I whant to be transparent for using that movie with a transparent bg as a layer in another program to do a composition with other movies. I found a way to do this, but frame by frame, and it is a lot of work.
__________________ |
| Hallowed Devil | aah, ye mean dat ye dnt want the black BG to appear in the movie..... well do 1 thing, render the sequence as a Targa Sequence wid 32bit Pre-mult Alpha. Wen you're about to import the sequence in the compositing sftwr, thr wud b n option on importing file as a Targa Sequence. Select this and select any 1 ov the targa files renderd. You'll see dat the whole sequence appears in the form on a single file or a layer. Thats it, the BG will appear only until ye add another things into the composition, aftr which ye start seeing no Black unwantd Bg :) hope tis works fr ye.....any queries, plz ask :)
| The Following User Says Thank You to shashanks18 For This Useful Post: | valahian1 (08-09-2009) |
| Registered User | IT WORKS !!! Thanks a lot! I did the same with tif format, but I was wrong with settings, and the program (After Effects) didn't take the images as sequence,but a lot of layers, one over the other, and my mind was blow up. Thanks again !!! ![]() ![]() ![]()
