| Registered User Join Date: Feb 2004
Rep Power: 0 ![]() | some problems with 3dsm Hey I'm having a problem with 3ds max 6 when I make a box I can change the sizes of that box ( the numbers on the right-length-width-height ) but when I make a new box or somethin I can change that sizes bu when I go back they're gone so I can't change the numbers from length-width-height..how do I get that back,,, here look at this And when I go back to my first object I can't see the numbers on the right how big the object is Can you help me? |
| Geekiness Extremeous Join Date: May 2003 Location: Nebraska Age: 23
Rep Power: 6 ![]() | Sure thing mate. The problem is you're still in the creation controls when you want to be using the modify panel. Just go up to the tabs on the right and click on the "modify" one. Then you can add modifiers and adjust all the properties of whatever object you choose. Hope that helps! Later. |
