Old 02-15-2011, 03:26 PM   #1 (permalink)
Rep Power: 0 RRVP is on a distinguished road
Some basic questions.
Hey Guys,
I'm quite new to 3ds max and i wanted to be sure of a couple of things regarding segments in an object.
1 - When you use pro boolean to extract objects from a bigger object, is it still possible to change the amount of segments in that big object once you have create the dent?
2 - Once you convert an object to editable poly can you also change segments in that object?
I ask this, because everytime i go to either of these things, my main object parameters dissapear and im not able to work on segments anymore. Also, it seems like i cant get rid of the conversions because there is no delete option for them as there is for the items in the modfier list.
Thanks in advanced.
RRVP is offline   Reply With Quote
Old 02-16-2011, 06:43 AM   #2 (permalink)
Myself
wexomania's Avatar
Rep Power: 0 wexomania is on a distinguished road
Send a message via MSN to wexomania
i dont think you can do it after pro boolean, but you can asign editable poly on top of your object without right clicking an selecting it there since it will then colapse youre moddifier stack, you can add editable poly on top of your modifier stack by selecting it under the same place you find bend, twist, symmetry... its quite high up in that pulldown menu
wexomania is offline   Reply With Quote
Old 02-18-2011, 03:44 AM   #3 (permalink)
Izmal's Avatar
go to modifier list problooean>subobject..
change segment (example in this case Box01 segments can be change after boolean with Geosphere01)
what do you mean by change segment?add polys after boolean?beavel?extrude..
just use editable poly selection because once you convert..its hard to go back. best way is to do backup or reference(clone) during modelling.
Old 02-18-2011, 09:50 AM   #4 (permalink)
Myself
wexomania's Avatar
Ah so it is possible to assign ProBoolean without converting, must have overlooked that thanks! :D
Old 02-20-2011, 02:20 AM   #5 (permalink)
Thanks a lot for the answers guys!
