Old 07-26-2007, 03:11 PM   #1 (permalink)
Rep Power: 6 josalgarcia is on a distinguished road
Rendering Hardware
Hello all,
I'm thinking of changing my BFG6800GS OC 256MB AGP card to a QUADRO FX3000 256MB. Do any of you know if by getting this card rendition time will improve? My current set up is:
CPU:Intel 3.2GHZ 800FSB 1M CACHE. (775)
MEM: 2GB 3200
Video card: BFG6800GS OC 256
MB: MSI MSI 865PE Neo3-F
Power Supply: 500W
Thanks,
Jose
josalgarcia is offline   Reply With Quote
Old 07-26-2007, 03:24 PM   #2 (permalink)
io read some place that autodesk recomend 4g ram if you use 3ds max. and it was somthing with a special build cad card for rendering.
try serch on autodesk home page.
www.autodesk.com
Old 07-26-2007, 03:41 PM   #3 (permalink)
Thanks Minimus,
I checked out Autodesk's page. But they recommend 4GBs for the 64-Bit version.
I guess I should have mentioned I have the 32-bit of Max.
Thanks for your input.
Old 07-26-2007, 10:55 PM   #4 (permalink)
Member
But it also depends on the 'type' of your rendering. If you renderer is using 'software rendering', upgrading your graphic card won't help since its using processor and your RAM for the rendering process while 'hardware rendering' will only use your graphic card for the rendering process. So you need to know, which hardware you should upgrade. However, a better graphic card will make you smoother when scrolling in the viewport that have many polygons.
Old 07-27-2007, 07:07 AM   #5 (permalink)
What would be considered software rendering and hardware rendering?
Old 07-27-2007, 10:47 AM   #6 (permalink)
Member
Depends on your renderer. Some renderer have the setting to choose which type of rendering that the user wants. Can I know which 3D designing software you are using and whats the renderer that you've assigned?
Old 07-27-2007, 06:48 PM   #7 (permalink)
I use scanline and MentalRay. I hope to some day try V-ray.
« Wormhole | RagDoll »
