Old 03-18-2009, 02:04 AM   #1 (permalink)
Dino
sdinesh86's Avatar
Rep Power: 0 sdinesh86 is on a distinguished road
render problem
please help me out..
i am building a character using 3DS max2009..
the character doesn't display when i render..whereas other geometry in view port renders. i tried finding solution in its object properties..i found none..
any one please help..
sdinesh86 is offline   Reply With Quote
Old 03-18-2009, 03:37 AM   #2 (permalink)
3dm3 moderator
Dr. D's Avatar
Oh no! What is the render? How we can help you if we don't know what is the render was? I know same problem has mental ray. chek your shader, delet it and make one again. I has same trouble in maya when i open my scen in highest version. Change main shader!
Sorry for the mistakes :)
Old 03-18-2009, 03:03 PM   #3 (permalink)
wingman103's Avatar
Rep Power: 5 wingman103 is on a distinguished road
yup dude post a render image so we can help u out
wingman103 is offline   Reply With Quote
Old 04-16-2009, 08:51 AM   #4 (permalink)
Stephen the Omnicient
3d3immolater's Avatar
Rep Power: 5 3d3immolater is on a distinguished road
if your using a third party rendering package like vray, brazil or final render you may need to check if the material you are using on your model can be rendered by the renderer you are using
try giving your model a basic "standard" material that anything will render
if that doesent work try flipping all the faces of your model, this sometimes happens when you import a model from a third party modeling program like zbrush or mudbox
hope this helps
cheers
As i walk through the valley of the shadow of death i will eat a steak, have a drink and listen to heavy metal till my ears bleed
3d3immolater is offline   Reply With Quote
