| Registered User Join Date: Jul 2006 Location: USA.. Miami Age: 36
Rep Power: 6 ![]() | Question about Quadro Video cards I just upgraded my BGF6800 to a Quadro FX3000. Does any one know when I will see the Quadro's "magic". When I'm working on the view ports, it still the same as my other card. I had heard from an Autodesk forum that Quadros are better when working on the view ports. My machine still stutters. Any suggestions, I'm I doing something wrong? I have a 2.8GHZ/1m/800fsb ( Hyper-threading) 2.0GB RMA AGP motherboard Win 2K |
| SkoleSlasken ![]() | first of all...the quadro card must fitt the motherboard. a good prosessor is important to. snd 2g ram.....i whould have pict around 4g. but i think most of the magic will come inn the render period. on how it handles to render out polys and such really fast.- but yes. they told us that allsow the speed inn the view port will be improved....have you down loaded 3ds max driver for the grapich card? that may do a diffrence.
Rep Power: 6 ![]() | No I haven't downloaded the 3D Max drivers for the card. I used the drivers of the CD that came with the card. I also read in Autodesk's web-site the even if I was to max out to 4GB's of RAM it wouldn't matter because Win2k can only see 2GBs and Win XP can only see 3GB. I'm working with the 32-Bit version of Max 9. Suggestions any one. Thanks for your input Minimus. Josalgarcia |
| Registered User | @minimus : as I know so far that the display card effect only on display thing, render process takes no effect from video cards, while render only CPU and RAM works as hard as they can. The different from Quadro and Geforce will appear while you working on Dynamic system and anything like particle and something more about it, more polygon face, more bandwidth on video cards lost, so as always a good video card will displays more face and more object on our screen. |
| Member | @paranoidx : It depends on the renderer itself. Some renderers use 'software rendering' where they use the processor and RAM, while some renderers use 'hardware rendering' where they use the graphic card to render the image. Some renderer allow the user to set what kind of rendering they want, while most renderer cannot be 'changed'. However, the graphic card will affect the viewport speed. Thanks :) |
| SkoleSlasken ![]() | i must say that i had wrong on the RAM part and to optimize every thing verry much you should putt inn a xeon processor. a xeon processor made for 3d can handle all up to 8g....but then you say xp only suport 3g...were have you heard that?
| | #7 (permalink) | |
| Registered User | Quote:
| | #8 (permalink) | |
I have found an old story on internet to explain this ^^ -------------- Intel Macs are Still Limiting RAM Usage to 2 GB under Windows XP I'm running Windows XP on my Mac Pro, but a really annoying limitation is that XP can only see 2 GB of my 5 GB of installed RAM. When I researched this a couple of months ago, I found out that this is a firmware/software limitation that can only be fixed by Apple and Intel. Until they make sure that Windows XP can see all installed RAM, using a Mac Pro for Windows production is severely limited.There's a widely spread misunderstanding that this problem can be fixed by using the /3GB switch in Windows' boot.ini file, but this technique can only be used to make certain applications use a bit more memory, as I showed in Using more than 2GB of RAM in After Effects, but it doesn't solve this problem at all. So what are the options? One is using Windows XP x64 or even Vista64 (for the adventurous) that will let you see and use all your installed RAM. You don't even need Apple's Bootcamp at all (not even for the regular XP.) Instead, add an extra hard drive and install Windows on the new drive (insert the installation DVD/CD, restart and hold down the C key to boot from it.) You can download the nVidia/ATI graphics drivers from the web, as well as the audio drivers from Realtek. The Apple keyboard works without drivers, and you just hold down the Alt / Option key when booting to choose which OS to boot from. Since you can't directly buy or upgrade to XP x64, I haven't tested this. I just hope that this info becomes more widespread, so that Apple/Intel fix this big limitation. - Jonas ---------------------- http://generalspecialist.com/ I think with this information will help you alot. Cheers. | |
| I like Chesse!!!! | This are the the specs on my machine: 2.7GHz 64-bit 4GB 1GB Nvidia PCI X16 and a sound blaster sound card And Vista 64-bit Ultimate
__________________ I hate plagiarism and those that plagiarize. Do not give me a reason to call you out you will not like it! yawn I love art |
| | #10 (permalink) |
| SkoleSlasken ![]() | wow not bad...but is Vista anny funn?
| | #11 (permalink) |
| I like Chesse!!!! | yeah its lots of funn, works wonder with 3ds max 9 SP-2 DirectX10 man its aswome!!!
__________________ I hate plagiarism and those that plagiarize. Do not give me a reason to call you out you will not like it! yawn I love art Last edited by bermudezis2005; 09-05-2007 at 01:36 PM.. |
| | #12 (permalink) |
| Member | I will never use Vista due to incompatibility for most of the softwares in my computer. Your computer is not bad, but I wanted to know what is 1GB Nvidia PCI X16? What model was that? As I know (In GeForce series) there isn't any card with 1GB RAM, and what for you need to write 'PCI X16'? That is the name for the 'slot', other than AGP, usually graphic cards will use PCI-e X16. |
| | #14 (permalink) |
| Member | Of course I know PCI-e is better than AGP, since AGP is only x8 and its still have other disadvantages. I'm sure your uncle can't make a card that named 'nVidia', since it must be using the nvidia GPU chipset (unless its a fake nvidia). If you don't know, you can check your dxdiag, all the system informations are written there (or just open your CPU casing and look at your graphic card, sometimes they will write the model of the card there) |
| | #15 (permalink) | |
| I like Chesse!!!! | he use the nvidea but he rebuilt the some extra ram on it DDR Quote:
__________________ I hate plagiarism and those that plagiarize. Do not give me a reason to call you out you will not like it! yawn I love art | |
yawn I love art
