Old 07-08-2008, 09:32 PM   #1 (permalink)
Rep Power: 5 anthonyduo is on a distinguished road
Send a message via MSN to anthonyduo
PFlow display render problem
I have a pretty interesting problem that I relly need sovled since the placement of where my particles hit the ground is very very important.
In the viewport I know where my particles are falling, everytime I play it in the viewport the places tey fall is ALWAYS the same, yet when I render it everything, all the particles are in completely different places.
Like I said I'm using 3ds max 2008, PFlow
anthonyduo is offline   Reply With Quote
Old 07-15-2008, 01:06 PM   #2 (permalink)
khuram shahzad's Avatar
Rep Power: 9 khuram shahzad
try to set the viewport display 100%, than u will c actual particle count and their position in the viewport in the same way they will render. Let me know if this helps.
khuram shahzad is offline   Reply With Quote
The Following User Says Thank You to khuram shahzad For This Useful Post:
anthonyduo (10-24-2008)
Old 07-15-2008, 04:09 PM   #3 (permalink)
They are all already at 100%. But I'll check it out anyway. No that didnt work. Let me post a picture of my problem.
PFlow display render problem-problem-max.jpg   PFlow display render problem-pf-itself.jpg
Old 07-23-2008, 12:44 AM   #4 (permalink)
Ok I did the 100% thing and it worked! Thank you very much. For anyone that searchs this topic you select the particle system icon in the VIEWPORT and then you'll find the things that will help you.
Old 07-24-2008, 01:59 AM   #5 (permalink)
Your are Welcome.:-)
