Old 06-01-2007, 01:39 AM   #1 (permalink)
Rep Power: 0 Zerstoren_QC is on a distinguished road
Moving show only bounding boxes
when i want to move the camera from where i am seeing the scene in 3ds max, it show only the bounding boxes and it's annoying. It was'nt doing that before.
here's a screen to understand
Zerstoren_QC is offline   Reply With Quote
Old 06-01-2007, 10:11 AM   #2 (permalink)
Kyo
Rep Power: 0 Kyo is on a distinguished road
Speed Modeling - Best Traditional Model Speed Painting - WINNER
Send a message via MSN to Kyo
clik "O" on keyboard
Kyo is offline   Reply With Quote
Old 06-01-2007, 07:18 PM   #3 (permalink)
Hey thanx !!!!
Old 06-01-2007, 08:08 PM   #4 (permalink)
Member
When your scene has many polygons, you can use this feature to make your scene 'smoother' when moving/rotating/zooming.
Old 06-04-2007, 11:28 AM   #5 (permalink)
Kyo
well, u know that the poly speed of 3ds max 9 can let u move a scene with more than 1.000.000 poly without any problams, try it, it's realy cool.^^
Old 06-04-2007, 07:47 PM   #6 (permalink)
Yeah, 3ds max will surely endle it, but i don't know if my CPU will endle it (Atlhon 64 2.0 GhZ)
Old 06-06-2007, 09:40 AM   #7 (permalink)
Kyo
no problam, poly speed use lots of ram, not CPU.
Old 06-06-2007, 01:19 PM   #8 (permalink)
Do you think i have enough ram (1.5 gig) ?
Old 06-06-2007, 09:13 PM   #9 (permalink)
Member
When its inside your viewport, it uses your graphic card. If you render (with software rendering) it uses your processor and RAM. So, if your viewport is slow when you have many polygons, that means your graphic card is not powerful to handle all the polygons smoothly. If you cannot render and you see insufficient RAM error message, that means your RAM is not enough for the renderer to render so much polygon. Usually this will not happen with MentalRay, but if you are using VRay (I'm using it for 3ds Max 8), you may get this easily when you have a heavy scene.
Old 06-06-2007, 10:52 PM   #10 (permalink)
That means i will have to upgrade some things on my PC because i have:
Athlon 64 2.0 ghz
1.5 gig
Asus GeForce 7600 GS 256 mb
it is slow when i get many poly (in the viewport) and, when i render, it is very long with v-ray. I think my graphic card and processor would need a little boost.
