| Registered User Join Date: Sep 2007 Age: 22
Rep Power: 0 ![]() | Hey, I was in the middle of finishing this building and i wanted to see things would look in a rendered image and i've noticed some things.. I was wondering if anyone would know how to fix these problems.. theres two problems, heres the first: (circled in red) http://img219.imageshack.us/img219/7866/display1az0.jpg and heres the second : (circled in red) http://img520.imageshack.us/img520/6302/display2fu8.jpg hope someone can help hehe.. thanks. |
| Member | I think those are mesh error. Check whether there is any mesh unconnected to the 'main model'. Actually, you can use splines to make those models, easier and have less polygons. Most important, will not have mesh problems if you use splines to make your wall. Thanks :) |
Rep Power: 0 ![]() | Mesh error huh?? hrm.. well i dont really know much on how to model with splines to be completely honest.. do you know how i could go about doing this with splines?? sorry for being a nub lol.. i've self taught myself so i dont have any really educated lessons on how to model. |
Rep Power: 0 ![]() | heres the backside of the Display2... it does appear that something is missing.. hope i can fix it without redoing the whole thing. ![]() ![]() ![]() [img=http://img170.imageshack.us/img170/4599/wireframegn1.th.jpg]im sorry my friend but i tried doing the [img][/img] code but doesnt work and i've never had success in doing it.. maybe im just doing it wrong. Last edited by Lantic; 09-24-2007 at 07:42 AM.. |
| | #11 (permalink) |
| Member | Since the image is too small, so I hope there won't have any vertices that I forgot to circle. The circled vertices are 'not needed' since that is just a straight line, how do you get the 2 vertices? The red line, shows that there should have a 'line', and why is there missing? (or it has been blocked by the 'front' part? I'm not sure, but there must have the 'line') I hope thats all and for other viewers, if you find any, please add in Thanks. |
| | #12 (permalink) |
| Registered User Join Date: Sep 2007 Location: Bangkok , Kingdom of Thailand Age: 28
Rep Power: 0 ![]() | do you use poly ? if you use poly that line maybe some connecting line. if you create some polygon that have hole. like that wall and window inside in polygon mode. it will have some connecting line between and can not delete it. if you change that polygon to mesh it disappear. but if it have some effect try make some new and see. you can write the wall and window with spline and attach it together than extrude it. you make good job don't worry it not that hard. |
