Old 05-25-2008, 09:42 AM   #1 (permalink)
ritchie
Rep Power: 0 Graff89 is on a distinguished road
Wink LIghting
After creting a couple of scenes how do I light the scene up Professionally. Moreso which type of lights should i use? Peace!!
Graff89 is offline   Reply With Quote
Old 05-25-2008, 05:19 PM   #2 (permalink)
what kinda lights you should use depends on what render you have and what light you want inn the scene.
if you render with v-ray the v-ray light is the best...thats kinda obious.
how to light up a scene professionally is kinda har du say....you should add light were a light source is inn your scene. if you have a lamp on the table...then add a light there to.
Old 05-25-2008, 11:58 PM   #3 (permalink)
Karpov's Avatar
Rep Power: 0 Karpov is on a distinguished road
Hello
I think that the "type of light" is not the important thing, but the settings of the render engine. With this I mean, over all, the global illumination (GI) that gives a very realistic lighting, specially when rendering a room.
If you are using the Default Scanline Render you won't be able to do so. You can use Mental Ray or V-ray, just like minimus said, to render your scene "professionally".
There are other engines, but they might be expensive and a bit harder to use than Vray.
Karpov is offline   Reply With Quote
Old 07-02-2010, 06:38 AM   #4 (permalink)
Rep Power: 0 maxi06 is on a distinguished road
yes
I totally agree with krpov.However lighting is very essential for our human live.
mini pendant lighting
maxi06 is offline   Reply With Quote
Old 07-02-2010, 07:44 PM   #5 (permalink)
milki's Avatar
actually you can render skylight in scanline, so you can have GI in scanline.
but yes, for nicer renders, scanline is not enough. (but is damn fast)
Old 08-02-2010, 10:41 PM   #6 (permalink)
Rep Power: 0 Leathür is on a distinguished road
Yes it all depends on what type of scene you are going for and also atmoshpere and environment come into play
Leathür is offline   Reply With Quote
