Go Back   Community for CG Artists > Main Forums > General Technology > 3DS MAX
Old 10-01-2006, 06:17 AM   #1 (permalink)
Rep Power: 0 momo54 is on a distinguished road
Help with Vray and glow
I'm working with 3ds max and Vray.
I have modeled a light bulb...
and I want glow on filament...
I've added the glow effect and it works fine..
but when the filament is behind the glass the glow disappears...
you can see it in the attached images...
10x :-)
momo54 is offline   Reply With Quote
Old 10-01-2006, 10:42 AM   #2 (permalink)
CG Artist
Real3d v.2's Avatar
Rep Power: 10 Real3d v.2 is on a distinguished road
Speed Modeling - Best Concept Model  Speed Modeling - Best Traditional Model  Speed Modeling - Best Concept Model  Speed Modeling - Best Concept Model
Total Awards: 4
Send a message via Yahoo to Real3d v.2
Why dont u apply Vraylight material to the filament and give it a yellowish color, that way it will emit light too :)
My Site Under Development:
www.digiarch.in
Real3d v.2 is offline   Reply With Quote
Old 10-01-2006, 01:22 PM   #3 (permalink)
I've tried it and it doesn't make the filament glow...
Maybe I just don't use it correct...
Can you tell me how to make the Vraylight material glow?
or any other way to get the result I wanted...
Old 10-01-2006, 02:57 PM   #4 (permalink)
CG Artist
Real3d v.2's Avatar
Total Awards: 4
hmm, lemme see, try this:-
If ur using 3dsmax 8, you can also apply Blur effect to the filament to make it look as if its glowing, only you will have to scale the object a bit bigger bcoz max will Blur out its edges. Blur is found in Environment and effects pallete in max8 ONLY.
If not using max8, Video Post will have to be done here coz Vraylight mtl emitts light but doesnt glow, sorry if I didnt told you this before.
Do this - Apply Vraylight mtl to your object and set its Object ID or channel to 1 or something other and remember it, go to Video Post and Apply Glow to the object using the ID you gave it (Hope you already know how to work in Video Post) and there, you will have your glow, Increase the intensity and have a smaller size of the glow! Hope this helps :)
www.digiarch.in
Old 10-01-2006, 03:10 PM   #5 (permalink)
I will find a tutorial for the Video Post and try it and the Blur effect...
10q :)
Old 10-02-2006, 07:44 AM   #6 (permalink)
I've tried both ways and it just doesn't work when the filament is behind the glass...
Not the Blur and not the Glow with the Video Post...
All of them work only when the filament is alone in the scene and there is nothing in front of it...
Does anyone know how to fix it?
Old 10-02-2006, 08:13 AM   #7 (permalink)
Rep Power: 14 minimus is on a distinguished road
Speed Modeling - Best Concept Model  Speed Modeling - Best Traditional Model  Speed Modeling - Best Traditional Model  Speed Modeling - Best Traditional Model  Low-Poly Modeling Award  Speed Modeling - Best Concept Model
How do you sett a ID on a objeckt? :)
Old 10-02-2006, 08:23 AM   #8 (permalink)
I've put 1 in the "Object ID" under the "G-Buffer" in the "Object Properties" window...
And set the glow to the same Object ID as the filament...
You can see in the pictures that it's work when the filament is alone in the scene..
But doesn’t work when the glass is in front of it...
Old 10-02-2006, 11:58 AM   #9 (permalink)
oldman
jidoman's Avatar
Rep Power: 10 jidoman is on a distinguished road
Speed Modeling - Best Traditional Model  Tournament Award  Speed Modeling - Best Traditional Model
Total Awards: 3
dont know much about vray and max but did u ask your self that could be the glass wrong?
i work with vinyls now
take a look : pegatinas redRadar
jidoman is offline   Reply With Quote
Old 10-02-2006, 12:15 PM   #10 (permalink)
Rep Power: 0 arquiyayo is on a distinguished road
Talking don't burn your head
hide all the geometry and render the filament only, save as *.tga and mix all in phtoshop. Then you can calibrate easily the glow, more even, yoy don need render any glows, you can create it in photoshop indeed.
:firedevil
arquiyayo is offline   Reply With Quote
Old 10-02-2006, 01:03 PM   #11 (permalink)
CG Artist
Real3d v.2's Avatar
Total Awards: 4
yes agreed but this shortcut wont work at all when animating or moving the camera!!!!!
www.digiarch.in
Old 10-02-2006, 01:46 PM   #12 (permalink)
hehe have a point there real_3d =P
Old 10-02-2006, 02:17 PM   #13 (permalink)
Does anyone have an idea for what to do in animated scene?
And what can be wrong in the glass?
Old 10-02-2006, 02:48 PM   #14 (permalink)
oldman
jidoman's Avatar
Total Awards: 3
glass? the glow is an effect , and beyond the glass the object u have is refracted through
the glass, so maybe u need to setup the glass to refract the effects too.
like i said, i dont manage 3dmax but is an ideea.
and if u have pacience maybe i will investigate for u ( and me)
Old 10-02-2006, 03:02 PM   #15 (permalink)
CG Artist
Real3d v.2's Avatar
Total Awards: 4
I am doing a test here, will get back to u guys in a couple of minutes!
www.digiarch.in
3DExport Buy & Sell 3D Models
Content Relevant URLs by vBSEO 3.3.2
