| Registered User Join Date: Sep 2006
Rep Power: 0 ![]() | Extruding problem Hi, I am currently migrating from Lightwave 9.0 to 3ds max 9. I am working on a tutorial to get me learning, but the tutorial is on lightwave. Here is the link: http://www.newtek.com/products/light...and/index.html I first created a PLANE, and then I adjusted the divisions (cutting). Now I want to extrude the hand so that I get a 3d hand... so I hit shift+e, and every thing seems to work ![]() ![]() But when I move a polygon from the side I just extruded, it doesnt seem to be "attached" to the other polygon ![]() What is the problem? I would have a 2 solutions: -Is it possible to tell Max to weld all the vertices that have the same coordonates? (in my opinion, it would be a very, very profitable plugin) -or is it possible to convert the polygon I just made to spline? because it seems to work way better with splines. thank you |
| SkoleSlasken ![]() | holding down shift alsow copys. so, if you select some polys hold down shift and move it you wil make a copy of that polygones and when you release you will gett 3 options copy as a own object or as a element or cansel :P
Rep Power: 0 ![]() | hmmm, I get the shift + e = copy, but I already tryed the extrude option in the drop down menu and it simply did not worked, in fact, it gave me the sides, but not the other "hand" what would be the best way to extrude this? |
