Old 08-13-2008, 09:47 PM   #1 (permalink)
Rep Power: 0 kurtis is on a distinguished road
Cannot get Edit Poly's to work correctly.
I am following one of the simple video tutorials that come with 3D Studio Max 2009. Specifically, the video that shows how to modify an object.
The problem I am running into is that I cannot drag the vertices around as shown in the video. I am able to create the cube, add more segments, add the "Edit Poly" modifier, choose the "Vertice Selector", and select some Vertices. However when I run my cursor over the Vertices (and red axis that represent them), I remain in select mode. In the side bar it constantly reports "<No Current Operation>". I can't figure out what I am missing here.
However I was able to use an option like "Extrude" in the "Edit Vertices" area in the side bar successfully.
I figure I must be missing something very simple and obvious but I can't figure it out. I've watched the tutorial video several times but I don't know what I missed.
Thanks ahead for any help.
kurtis is offline   Reply With Quote
Old 08-24-2008, 03:11 AM   #2 (permalink)
Hairy Snowman's Avatar
Rep Power: 0 Hairy Snowman is on a distinguished road
You must activate the select & move tool located in the tool bar. If you mouse-over the buttons for a couple seconds it will tell you the name of the tool. You can also use the keyboard shortcut which is the W key.
Hairy Snowman is offline   Reply With Quote
Old 09-02-2008, 01:31 PM   #3 (permalink)
Main Gallery Moderator
iamtravis316's Avatar
also the shortcuts for those tools usually are
Q= for select,
W= select and move,
E= select and rotate,
R= select and scale.
Oi Oi Oi
