| Registered User Join Date: Oct 2007 Location: Serbia Age: 29
Rep Power: 0 ![]() | If i understand you, what you did was "union", so both operands keep showing. It is the option in boolean panel. You should do "subtraction (A-B)" or "subtraction (B-A)", depending which object was selected in the moment of applying boolean operation. So: select "queen", apply boolean, "pick operand B", select box, check "subtraction (A-B)" button. Be sure that in "display/update" panel (below) is checked "result", and at "update" panel "auto" is checked. Hope i helped, if i understood problem correctly. And sorry for my bad english too;) |
