| Registered User Join Date: Jun 2010 Age: 22
Rep Power: 0 ![]() | 3ds,zbruh,texturing help 3ds,zbruh,texturing help I Everyone want to learn more about 3d modelling but i really don't know where to start.I'm the king of noobs in 3ds and zbrush and in texturing i really don't know where to start.Can someone help me pls ?
__________________ 3d Models |
| Registered User Join Date: Nov 2010 Age: 28
Rep Power: 0 ![]() | There are all sorts of both free and pay tutorials out there and in my opinion that is the best place to start. The paid tutorials are generally more in depth and will teach you a lot, but free can get you a long way as well. Don't forget about youtube, there is a lot of garbage on there but there are also a lot of valuable videos and with HD finally tutorials are actually usable on youtube. |
| Registered User Join Date: Jan 2008 Age: 27
Rep Power: 0 ![]() | you should start with 3ds first and then move to zbrush...learn the modeling part first and then start and learn how to texture
__________________ Tutorials for 3ds Max |
| Registered User Join Date: Jan 2011
Rep Power: 0 ![]() | The user is normally given the option of disabling Active Desktop through the display properties. This tweak removes the ability to disable Active Desktop. Open your registry and find the key below. Create a new DWORD value named "ForceActiveDesktopOn" and set the value to "1" to force the use of Active Desktop. [HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer][HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\Explorer]Value Name: ForceActiveDesktopOnData Type: REG_DWORD (DWORD Value)Value Data: (0 = default, 1 = enabled)* This tweak will remove the Active Desktop options from Settings on the Start Menu. Open your registry and find the key below. Create a new DWORD value named "NoSetActiveDesktop", and set the new value to equal "1" to enable the restriction or "0" to disable the restriction. Note: This restriction can be used either on a user by user basis by adding it to HKEY_CURRENT_USER or on a computer wide basis by adding it to HKEY_LOCAL_MACHINE. [HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer][HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\Explorer]Value Name: NoSetActiveDesktopData Type: REG_DWORD (DWORD Value)Value Data: (0 = disable restriction, 1 = enable restriction)*This tweak allows you to have Active Desktop enabled, but to restrict any changes to the settings. Open your registry and find the key below. Create a new DWORD value, or modify the existing value called 'NoActiveDesktopChanges' set the value to equal '1' to enable the restriction. [HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer][HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\Explorer]Value Name: NoActiveDesktopChangesData Type: REG_DWORD (DWORD Value)Value Data: (0 = disable restriction, 1 = enable restriction)* Features of the Windows Active Desktop can be selectively controlled by modifying options in the Windows registry. Following the instructions in this tweak. Open your registry and find the key below. Create a new DWORD value based on the options below, and set the new value to equal "1" to enable the restriction or "0" to disable the restriction. NoChangingWallpaper - Disable the ability to change wallpapers. NoComponents - Disable components. NoAddingComponents - Disable the ability to add components. NoDeletingComponents - Disable the ability to delete components. NoEditingComponents - Disable the ability to edit components. NoCloseDragDropBands NoMovingBands - retrict adjustments to desktop toolbars NoHTMLWallPaper - only allow bitmaps (BMP) as wallpaper Note: These restrictions can be used either on a user by user basis by adding it to HKEY_CURRENT_USER or on a computer wide basis by adding it to HKEY_LOCAL_MACHINE. [HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\ActiveDesktop]System Key: [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\ActiveDesktop]Data Type: REG_DWORD (DWORD Value)Value Data: (0 = disable restriction, 1 = enable restriction)
__________________ xbox live points |
| Member Join Date: Apr 2011
Rep Power: 0 ![]() | person to person to wow gold vocalization.Is a war is with, is wow gold buy solace definite by the region in summer guild wars gold Denote for not to promote for gold for wow to transfer troops assist wow gold now staple gain not to hold. |
| Tags |
| 3d job, 3d models, 3d models free downlaod, 3d video, 3d video tutorials |
