Old 03-10-2006, 06:48 PM   #1 (permalink)
Rep Power: 0 l2edl2azor is on a distinguished road
Question 3D Max question (help)
How can this be done in Max? For example, I would like to apply text to a convex or concave surface. And can you apply a small bitmap to a large surface? like what I'm trying to do here.
The text here is actually in front of the red wheel and I would like to apply it to the wheel either as a bitmap or ???????? Some one explain this to me and I'll make a tut on how to do this.... Thanks RR
l2edl2azor is offline   Reply With Quote
Old 03-12-2006, 03:50 PM   #2 (permalink)
Kazus's Avatar
Rep Power: 3 Kazus is on a distinguished road
I dont understand the question, but maybe UVWmap or UnwrapUVW modifiers can help you.
И тут Остапа понесло......
Auto-3d(Russian resource)
Kazus is offline   Reply With Quote
Old 03-12-2006, 06:29 PM   #3 (permalink)
CG Artist
Real3d v.2's Avatar
Rep Power: 3 Real3d v.2 is on a distinguished road
Speed Modeling - Best Concept Model Speed Modeling - Best Traditional Model Speed Modeling - Best Concept Model Speed Modeling - Best Concept Model
Total Awards: 4
Send a message via Yahoo to Real3d v.2
hmmm...
I dont get the question either! but you can make a bitmap of text, apply it on an object with UVW map modifier and do some adjustments with the Alpha settings of the material! make it in photoshop! and one more way -
you make text in max in create panel, place it on object and then unify it with boolean operation! may this will help........ :)
Real3d v.2 is offline   Reply With Quote
Old 03-20-2006, 10:43 AM   #4 (permalink)
Rep Power: 0 Hires is on a distinguished road
Make a text, use alpha for transparent level, make a multi material (it's standart material type in 3D Max, dont remember name) whitch makes ID for each sub-map, then edit poly, select front area of a place where text must be (here - front of a wheel), assign ID 1, and in multi material assign ID1 for text map. Use UVW Map with ID1 for this map.
Here you have a text, then use another maps with another ID's fo other texturing.
Hires is offline   Reply With Quote
Old 02-20-2007, 06:02 AM   #5 (permalink)
ramkishor
Guest
hey how can i place a jpeg image as my back ground in 3ds .avi output
Old 02-20-2007, 03:25 PM   #6 (permalink)
oldman
jidoman's Avatar
Rep Power: 3 jidoman is on a distinguished road
Speed Modeling - Best Traditional Model Tournament Award Speed Modeling - Best Traditional Model
Total Awards: 3
render menu choose environment
where u see backgroud choose a map (your jpeg)
and then make a instance draging that map in the material editor ( choose screen)
hope i was clear enough
________ _____ _________
______(_)___(_)______ /______ _______ ___ ______ ________
_____ / __ / _ __ / _ __ \__ __ `__ \_ __ `/__ __ \
____ / _ / / /_/ / / /_/ /_ / / / / // /_/ / _ / / /
___ / /_/ \__,_/ \____/ /_/ /_/ /_/ \__,_/ /_/ /_/
/___/
http://www.telefonica.net/web2/vision3d/
jidoman is offline   Reply With Quote
