| CG Groups | Register | Blogs | FAQ | Members List | Calendar | Mark Forums Read |
| Registered User Join Date: Aug 2007 Age: 25
Rep Power: 1 ![]() | render time is 11h!!help hey. here you can se the pic,well nothing special on it just acar with reflections...now the problem is the time. i had tried differents setting each time i wanna render the car but still got huge time of render. i need to know where i got wronge on the setting,material,anything that caused this render time. gonna post as much as i can of information about the whole scene so meybe it will help ya figure out whats exactly my problem.the second pic is only 30 min with low quality settings. cause there is a limit for the attachments so i uploaded my pics and the materials else where. hope this will not prevent you from viewing my info. there is the max file also ziped from 106 mega to 16. 106 mega for acar is too big isnot? meybe here is my problem. forgot to mention iam using vray. also i got my first clay models here:http://www.3dm3.com/forum/showthread...8965#post48965 again thanx for help pics: ![]() ![]() http://rapidshare.com/files/57651168..._info.rar.html http://rapidshare.com/files/57656246/max_file.rar.html ![]() |
| Registered User | if you change the indirect map built in presets from High to meduim abviously the time will dicrease a lot you have used HDRI but i cant see it in environment my self i havent used such lightining system , maybe you are doing it in the right way but i always try it with vray sky and a vray light but the vray light should be dark hope it helps
Rep Power: 1 ![]() | well..what i can say..iam almost depressed!i tried with light, without lights...many methodes untill i got the last one. also made it in day light. but still the same damn render time. i cannot wait 11 h for each render.gonna se what medium do to my scene. also you can try it in your pc. i uploaded the files. about hdri i donot used now. but used it before in day light..... thax for help Last edited by hungryleo; 09-23-2007 at 12:33 PM. |
| SkoleSlasken Join Date: Dec 2004 Location: Norway (Trondheim) Age: 18
Blog Entries: 4 Thanks: 10
Rep Power: 6 ![]() | what hardware do you have in your computer?
Rep Power: 6 ![]() | sorry i dont know much about vray, all i know is that it often takes a lot of time, my renders of simple scenes takes around 4h-8h. you can take the subdivs under irradianc map down to 30, becaus the scene will not use more than that. and the light cache can be putt down to 1000 from 2000. i dont think it will make a big differenc on the quality. dissplace ment often takes long time, but there i dont know the settings, just take a look at it. you have a very shiny picture, fallof is a bad ass on rendering time, so if your scene is full of that you might turn some of or somthing. if you turn down the sampeling on the lights that will alsow speed up your rendering time, but lower the bouncing and rays the light will break up in when hitting ground. i will take a look at you uploaded files tomorrow and see if i can find anything from them cheers and good luck ![]()
__________________ Det som ikke dreper deg gjør deg stærkere :thumbsup: Norge Last edited by minimus; 09-23-2007 at 04:10 PM. |
Rep Power: 1 ![]() | thax for the info......now the problem here with vray setting i think. i changed the material of the body to asimple one, but still the render so slow.changed the cache and also the subdivs. still realy bad. well...i think nothing to do with it....its my pc. the file should work with vray..so you cannot render it. anyway thx for help......gonna change the scene lights and see what happens |
