Old 06-24-2003, 12:23 PM   #1 (permalink)
Lilith's Avatar
Rep Power: 6 Lilith
Max 5 render
Hi!!
I need to know where can i find render for 3Ds max 5 (5.1)
Lilith is offline   Reply With Quote
Old 06-25-2003, 01:30 AM   #2 (permalink)
Rep Power: 6 Jomama
Check the post in this forum called Render-Help- it's also at
http://www.3dm-mc.com/forum/showthre...=&threadid=907
Jomama is offline   Reply With Quote
Old 06-25-2003, 01:00 PM   #3 (permalink)
Lilith's Avatar
Rep Power: 6 Lilith
I am very weak in english (I can't read that Render-Help-)
Old 06-25-2003, 01:50 PM   #4 (permalink)
3DM Administrator
:deal:
brazil - heard a lot about it, used the trial..hope to purchase the full version soon. (love the effects)
illustrate - good cartoon shader(vector)...illustrator,swf file.
VRay - Chaosgroup product, very fine render!
finalrender - havent try it...soon
mental ray - good for metal shines stuff..from discreet.
renderman - pixar's..but never tried it before.
:thumbsup:
(c) Izmal
Old 06-26-2003, 12:26 AM   #5 (permalink)
Izmal's Avatar
Rep Power: 6 Izmal is on a distinguished road
thanks Stryker..
just want to add another useful site:
http://www.pointzero.nl/renderers/
hope this helps....:alc:
Old 06-26-2003, 12:07 PM   #6 (permalink)
Lilith's Avatar
Rep Power: 6 Lilith
:coolp::beer:Thanks to all
VRay is my choise
Old 06-27-2003, 12:49 AM   #7 (permalink)
Rep Power: 6 Jomama
Does the free Vray max 4 work with max 5? Otherwise I'll have to use the demo I guess.
Old 07-04-2003, 04:36 PM   #8 (permalink)
Rep Power: 6 Jomama
Still waiting for reply on above question of mine..:D
Old 07-04-2003, 06:23 PM   #9 (permalink)
3DM Administrator
Yes, Vray work with 3ds max 5!
Old 07-05-2003, 08:58 AM   #10 (permalink)
scio nihil scio
Sokratas's Avatar
Rep Power: 6 Sokratas
I got it too !
Old 07-06-2003, 12:34 AM   #11 (permalink)
Rep Power: 6 Jomama
I don't know why, but when I render this one scene of mine it takes out the background and I don't know if I have everything because I checked the manual for it and I don't have a couple files. But I don't know why I wouldn't have them? Help is needed if you know why I have this problem. It might just be that I don't have all the files, but I downloaded and installed to the right directory. Hmm.
Old 07-06-2003, 03:47 AM   #12 (permalink)
Rep Power: 6 Pyros is on a distinguished road
Jomama, dioes it happen with one file only or is it happening with all of your files??? I f it is only one file... VERY STRANGE --- I suggest that you try merging you "bizarre" file with a new file and see what happens... If ti happens with all of your models, try dowloading it again, because sometimes the file s may come corrupted due to trasfer errors that are too subtle for the download to be interruprted butn that, in some cases, corrupt the files so that you can't use them...
Good Luck and tell me if I was right.. please---!!!JAJAJA
Old 07-06-2003, 12:59 PM   #13 (permalink)
Rep Power: 6 Jomama
Hmm, ok I rendered a couple other scenes and it didn't take out my enviroment so maybe it's just that one scene. I redownloaded vray and tried the same scene and it still did it. But also, shouldn't the images rendered with vray look better than the default renderer? Or is because I didn't tweak any of the settings.
Old 07-07-2003, 05:41 AM   #14 (permalink)
pradipta's Avatar
Rep Power: 6 pradipta
hi ...
i am working on 3dsmax for a long time and i found that 3dsmax 5 rendering engine is very powerful. well, if someone want to invest in a external rendering program then it's well and good but what i meant to say is, 3dsmax 5 scanlins 1 renderer is quite efficient and great improvement from 3dsmax 4. i do all my rendring in default rederer. recently i am working on a project on a modeling and rendering of a wall and i posted it in wip section named 'Architecture: a decorated wall in daylit' and you will see good effect can be achieved with max. but, yes, it takes a pretty long time.
so, in that case vray is good although i have not used it but, seen some great stuff.
pradipta is offline   Reply With Quote
Old 07-07-2003, 03:26 PM   #15 (permalink)
Rep Power: 6 Jomama
Yeah, that wall you made is really good :coolp: When I use vray it kind of leaves a blurry edge around some objects, I guess there is a setting to change that? Hmm, but for now I guess I'll just use the default.
