Old 04-30-2004, 06:48 PM   #1 (permalink)
Rep Power: 0 uOkO
Low quality .avi render
Hello!
I've got a problem or a question... If I render only one frame of a scene (animated) it's good quality with details. If I want to render more frames as an animation I get low details and bad quality. I change compression to 0% butit's still the same.
It looks like it would be 16 bit color instead of 24 or 32...Any idea on this one?
I use 3DS MAX 4, standard render engine.
Thanks!
uOkO is offline   Reply With Quote
Old 05-01-2004, 03:29 PM   #2 (permalink)
3DM Administrator
Need to put Full frames (without compression) options Not compression to 0%.
Old 05-01-2004, 06:31 PM   #3 (permalink)
Rep Power: 0 uOkO
Did not help much... The quality is a bit better, but still much worse than normal render... Thanks anyway!
Old 05-18-2006, 04:06 AM   #4 (permalink)
Kage's Avatar
Rep Power: 3 Kage is on a distinguished road
Send a message via MSN to Kage
I tend to notice this too.
If you have a composition program though, its possible you can resolve this.
Simply render out image files instead in frames, and then within a program, add all of the pieces back together, saving out with a better compressor.
Back here for good :D
Check out my latest thread:
http://www.3dm3.com/forum/f24/logitech-z-5500-a-14809/
Kage is offline   Reply With Quote
