Old 04-05-2004, 08:48 PM   #1 (permalink)
Rep Power: 0 TomorowsMemory
Brazil (Reflections and Skylight HELP)
ok this is the problem. When I use the default renderer everything is fine, I have "Flat Mirror" on under the reflection map and when I render with Brazil there is no longer the reflections on the materials, another problem is with the skylight. I turned on skylight and it workes fine with direct lighting but when I turned on Indirect lighting I get a black screen when I render, what can I do to fix those 2 things? please help, thank you.
TomorowsMemory is offline   Reply With Quote
Old 04-16-2004, 06:25 AM   #2 (permalink)
death from above
sirpalee's Avatar
Rep Power: 9 sirpalee
Send a message via MSN to sirpalee Send a message via Yahoo to sirpalee Send a message via Skype™ to sirpalee
Hi!
Maybe try to use raytrace reflections with the mirror, that will work with brazil. Have you turned on in indirect illumination the skylight? Turn on in each (indirect and direct also).
There is no fate.
Only possibilities of virtually unlimited random events.
Some have greater chance, some have smaller.
If we are good, we can change the chances, to get the derised flow of events.
sirpalee is offline   Reply With Quote
