Old 01-11-2004, 10:11 AM   #1 (permalink)
Rep Power: 0 Dooid
Question 2D Render
Hi, Im learning how to use 3ds Max 6 and I have come across a small problem, the literature I'm learning from tells me to render a 2d spline into 3d by going to the command panel -> rendering -> choose viewport and so on but I can't select viewport its always on renderer. Is there another way around this problem? I'd appreciate any help. Thanks
Dooid is offline   Reply With Quote
Old 01-12-2004, 11:55 AM   #2 (permalink)
Geekiness Extremeous
DVeditor's Avatar
Rep Power: 9 DVeditor
Yes. You can render a spline (make it renderable) by going into the parameters of the object (the "modify" tab) and clicking on the "renderable" check-box in the "rendering" rollout. Hope that helps you!
Later.
- CK Hicks -
My Website
deviantART Gallery
DVeditor is offline   Reply With Quote
Old 01-12-2004, 08:11 PM   #3 (permalink)
Rep Power: 0 Dooid
hi thanks for your reply. If figured the problem out, I wanted to see it in the viewport but i couldnt select viewport over renderer. What i did was tick 'use viewport setting' and this allowed me to select viewport. Never a dull moment with 3ds max.
Old 01-14-2004, 02:51 AM   #4 (permalink)
Rep Power: 0 raul
sdfsdfd
raul is offline   Reply With Quote
