| Main Gallery Moderator ![]() | Which way should i texture this? i would put this in the WIP section but it wont let me post in the weapons section. and i was just going to post this when i was done with it but i had a quick question for yall which way do yall think i should go about texturing this axe. 1. just apply the textures and use the uvw modifier or.... 2. unwrap it heres my model. ( I also attached the original) ![]() ![]() |
| TUSC Ringleader ![]() Join Date: Jul 2008 Location: USA, Pennsylvania Age: 32
Rep Power: 5 ![]() | i don't know how to unwrap so i can't suggest anything for you, but i'd like to see the final. looks good. |
| The Following User Says Thank You to mikeab7925 For This Useful Post: | iamtravis316 (12-30-2008) |
| Hallowed Devil | hey Travis, frankly if ye're unwrapping it, it'll take loads ov patience n difficulties, as tis is a very complex model to unwrap...... wat ye cn do is.....goto Polygon mode, scroll dwn to Polygon Properties n giv each group ov polygons a different Material ID. nw giv tis model a single material in the material editor. n in place ov "Standard" material, gv "Multi/Sub Object", choose "discard old material" n den set the number ov materials to the no. ov Material ID's ye hv given to the model.....n dats it, gv each material a different texture, n in the end, jus gv a "UVW mapping" modifier to properly map the textures on the model..... do post the final output :D
| The Following User Says Thank You to shashanks18 For This Useful Post: | iamtravis316 (12-30-2008) |
| Member | Of course, if you can unwrap it, I would recommend you to do that. With an unwrapped model, you have a lot more 'possibilities' that can be made on your axe, such as 'painting' blood on it or scratches on it at desired places (that's only when you want to make it look like a used axe instead of a new one). Thanks and good luck texturing it :) |
| The Following User Says Thank You to Need_Help For This Useful Post: | iamtravis316 (12-30-2008) |
| Hallowed Devil | well, fr blood stains, ye cn put a "Splat" material, n in 1 color, add the basic texture ov axe blade, n in the other color, give Red color, n no map...i've made a basic axe lying in a blood stained mud-pool dat way...fr scratches n all....yea, v do hv limitations :P
| 3dm3 moderator ![]() | Hi Travis! do you can't create mapping (UVmapping)? It's so easy. Use soft UVLayout, i recomend!!! If you want i can create mapping today if you send me model (obj or fbx). It's very easy.
__________________ Sorry for the mistakes :) |
| The Following User Says Thank You to Dr. D For This Useful Post: | iamtravis316 (12-30-2008) |
| | #10 (permalink) |
| Supreme Digital Artist | Hey, me like it :D... I must agree with Need_Help here, but honestly I don't know how to unwrap an object... lol Cheers ![]() |
| The Following User Says Thank You to SDA For This Useful Post: | iamtravis316 (12-30-2008) |
| | #11 (permalink) |
| Member | It looks really nice :) Keep it up! I'm looking forward for the finished product. Thanks. |
