| Registered User Join Date: Oct 2008 Location: uk Age: 24
Rep Power: 0 ![]() | Engraving Im after engraving some text into a wall, but every time i go to do it for sum reason or other it comes up like this when rendering http://i36.photobucket.com/albums/e1...ers/Image1.jpg after creating some text im going to bevel then boolean, tried extrude then boolean but still no joy Anyone give me some advice ? Many Thanks |
| SkoleSlasken ![]() | have you tried to subdivide the wall that your carving inn to? to give it more polys to work on?
| SkoleSlasken ![]() | you can tesselate the wall with a tesselate modifyer. or simply select all edges around and hit conect and make more polygones. you can aslow use turbosmooth modifyer but then you need to chamfer the edges to keep the hard edges. how much experience do you have in 3ds max from before?
| SkoleSlasken ![]() | ye i know bolean and carving stuff can be a pain. whats important is to clean up the mesh after you have carved, that way you prevent bugs like the black pices as inn you picture.
| | #8 (permalink) |
| SkoleSlasken ![]() | manualy. after a bolean there is often edges and verts on the wrong track. make sure every vert have a edge going to them and try even out hte polys so you gett quads....a bit hard to explain.
Rep Power: 0 ![]() | sorted it thanks mate, added a few more lines in the box n its seems to have turned out better, ( still not perfect ) But its fine for now, thanks a bunch |
