Old 05-01-2007, 06:18 PM   #1 (permalink)
Rep Power: 0 Fiori is on a distinguished road
3D Max Biped Help
Hi all im doing this animation for my project and we are allowed to use pre-build models. I found a great model but whenever i rotate it or scale it messes up, its as though it is pivoting around the red dot, which I have no clue what it is as i cant select it. I figure its something to do with the biped and something to do with the single footstep as displayed on the picture. I just want to get rid of it so that I can do more with the model than just move it around (which i can do without the model messing up)
thanks in advance for any help
Fiori is offline   Reply With Quote
Old 05-02-2007, 08:38 PM   #2 (permalink)
any help at all ??
Old 05-06-2007, 05:36 AM   #3 (permalink)
capricorn's Avatar
Rep Power: 0 capricorn
which part are you intending to move? The red dot should be the pivot point of the foot if not wrong. It'll affect the movement of the pivoted limb (such as foot) if it's in planted & sliding key (IK). If you want to ignore the pivot influence on it, clicking "free key" will free you from it. Hope it helps :)
Life is but a dream...
http://www.3d-fanatic.com/
capricorn is offline   Reply With Quote
Old 05-07-2007, 01:21 PM   #4 (permalink)
Thx for the advice, it seemed to get rid of that issue, although there is another problem to do with trying to access the footstep mode as it is unavailable to select, any advice on why this would be?
Old 05-08-2007, 12:49 AM   #5 (permalink)
capricorn's Avatar
did u activate the subobject "footsteps" under footstep mode? I supposed u want to select the individual footsteps.
Old 05-08-2007, 01:14 PM   #6 (permalink)
The thing is I cant even access footstep mode. I want to try and make it run or do some kinda foot action via using the footsteps, but its not slectable for some reason
