Old 10-17-2007, 04:58 AM   #1 (permalink)
.: AnTi :.'s Avatar
Rep Power: 5 .: AnTi :. is on a distinguished road
problem with blueprints
i have a problem.
i use 3d max 9 at 32 bit. i make a plane i add on it a material with diffuse a bitmap with a part of the blueprints but the blueprints is blurred and of a bad quality in 3dm.
i post the project and a screen shot of my problem. please help me.
problem with blueprints-picture001.jpg   problem with blueprints-picture002.jpg
.: AnTi :. is offline   Reply With Quote
Old 10-17-2007, 05:00 AM   #2 (permalink)
.: AnTi :.'s Avatar
more screen shot
problem with blueprints-picture003.jpg   problem with blueprints-picture004.jpg
Old 10-19-2007, 11:09 AM   #3 (permalink)
amin2001's Avatar
Rep Power: 6 amin2001 is on a distinguished road
Speed Modeling - Best Traditional Model Speed Modeling - Best Traditional Model Speed Modeling - Best Concept Model Speed Modeling - Best Traditional Model Speed Modeling - Best Traditional Model
Total Awards: 5
Send a message via Yahoo to amin2001
Hi Buddy
Follow the steps : 1_customize 2_prefrences 3_viewports 4_configure driver 5_ follow the attach image !!
let me know if the problem is solved
keep up
FERRARI F430 ( WIp)
amin2001 is offline   Reply With Quote
The Following User Says Thank You to amin2001 For This Useful Post:
Stryker (11-17-2007)
Old 10-19-2007, 12:43 PM   #4 (permalink)
.: AnTi :.'s Avatar
what didi you mean with steps : 1_customize 2_prefrences 3_viewports 4_configure driver what i must do ???
Old 10-20-2007, 03:10 AM   #5 (permalink)
amin2001's Avatar
Total Awards: 5
emmm , Go to Customize as you see in the attach
then similar to this , find the others !!
FERRARI F430 ( WIp)
Old 10-20-2007, 03:35 AM   #6 (permalink)
Member
Go to Customize->Preferences then under viewport click on Configure Driver...
Change Background Textures size and Downloaded Texture size to 1024 and check both Match Bitmap Size As Close As Possible.
Restart 3DS max and you're done!
This is my answer in another forum a few months ago (same as his answer), just copied and pasted :P
Old 10-20-2007, 05:38 AM   #7 (permalink)
.: AnTi :.'s Avatar
ohoh i understand sorry :P if i use max 6 it's the same prob. i must do the same on max 6 ??
edit: ok i make the same on max 6 now i control if it's work.
Old 10-20-2007, 05:53 AM   #8 (permalink)
.: AnTi :.'s Avatar
it' better but not the best... mayby i have a fu**ing Direct3D driver... have someone had a direct3D 9 ??
Old 10-20-2007, 06:04 AM   #9 (permalink)
Member
Maybe you can try to update your DX9 to DX9.0c latest version. Did you restart your 3DS Max after you changed the settings? It's important because it will not take effect if you don't restart your 3DS Max. If its still like that, try to enable 'Antialiased Lines in Wireframe View' (the checkbox above Background Texture Size.
Old 10-20-2007, 06:23 AM   #10 (permalink)
.: AnTi :.'s Avatar
yes i restart 3ds max but it'still like in the last screen shoot... i can't find the DX9.0c... i find one but i don't know hoe to install it :P ^^
thanks for your help
Old 10-20-2007, 06:35 AM   #11 (permalink)
.: AnTi :.'s Avatar
the Antialiased Lines in Wireframe View don't change anithink
ok ill pass... i try to work with the blueprints like that....
if it can help you i have a pavilion zd8000 with an ATI mobility radeon x600 and the directX 8.1...
i try to start modelling hope i can make somethink
Old 10-20-2007, 07:04 AM   #12 (permalink)
.: AnTi :.'s Avatar
help me i can't work with this fu**ing blueprints :(
Old 10-20-2007, 08:17 AM   #13 (permalink)
Member
Once you've downloaded DX9.0c, just open the .rar file and find a .exe file named Setup or whatever name that 'sounds' like a installation file. However, I don't really think that its the version of DirectX that causes this problem, it looks like it was caused by your Max. Try to contact Autodesk and I think they should know how to fix the problem.
Old 10-20-2007, 09:48 AM   #14 (permalink)
.: AnTi :.'s Avatar
ok i try .... now i have a problem with modelling... i have a video tutorial... and in a moment he select a vertice (in poly) and click on a opposite segment and Max create the segment from the vertice he select to the point of the segment he click... How to make this ????
If u don't understand tell me
Old 10-20-2007, 10:11 AM   #15 (permalink)
.: AnTi :.'s Avatar
hope someone help me
