Old 02-12-2004, 03:33 PM   #1 (permalink)
Muad'Dib's Avatar
Rep Power: 0 Muad'Dib
Lathe
Everytime I lathe some profile, like a spline or any other closed curves that has vertices, the final model always has a tiny hole in the vertice. Am I doing something wrong? Is there a way to avoid the cration of this hole? Is there any away of capping this hole?:togo:
Muad'Dib is offline   Reply With Quote
Old 02-12-2004, 06:12 PM   #2 (permalink)
word up yo
Rep Power: 10 Razor-
in the lathe menu activate the 'weld core' option ... this should work
www.razorcd.com
Razor- is offline   Reply With Quote
Old 02-12-2004, 09:09 PM   #3 (permalink)
Rep Power: 0 redsky
check your spline and make sure all the vertices are welded.
1. click and drag over one vertice im
2. weld option turn the spinner to 3.0
3. click weld
4. do this to all your vertices when finished
5. click lathe
6. lathe modifier click + to extened yellow axis
move axis and wld core if required
redsky is offline   Reply With Quote
Old 02-13-2004, 06:59 AM   #4 (permalink)
Muad'Dib's Avatar
Lathe
Thank you guys. I've tried the weld core option and it worked out. I'll try the other alternative too.:thumbsup:
