Old 04-10-2007, 06:08 AM   #1 (permalink)
redzuan3828
Guest
How to model faster using 3ds max 8?
Seen I'm begin draw with Autocad (2d drawing), then my work flow is like this
1) Trace floor line in Autocad
2) Import in 3ds max then extrude (-150mm) the floor line become floor.
3) Create wall in front viewports using rectangular, convert to
editable spline
then extrude and Edit Mesh Modifier
4) Using floor shape as a guide to put every wall by copy it. Go to editable
spline>segment then adjust using snap point on to suit the lenght of floor.
Create 45 degree every wall edge.
5) Create opening by using rectangular. Give rectangular correct size then
using snap point and align to locate the opening. After that
attach it using editable spline
Done the wall + opening and floor as guidence
Can somebody share others workflow?
any opinion are welcome
Old 04-10-2007, 07:20 AM   #2 (permalink)
Elyu's Avatar
Rep Power: 6 Elyu is on a distinguished road
I think u can do the floor use a plane then add "Shell" and in 3ds max there's a geometry named "wall"(do the spline as the base, then use wall picking the spline) u can add windows to the wall to and "Wall" will do a hole for the windows by himself.I hope this can help u and sorry for bad eng.
Elyu is offline   Reply With Quote
Old 04-10-2007, 10:21 PM   #3 (permalink)
redzuan3828
Guest
Thanks elyu
This technic is new for me...but very fast and good...
I will use it... before that...
Did you got any problem doing highrise or bigger scale project using this technic?
Thanks again....
any others opinion guys????
Old 04-11-2007, 10:15 AM   #4 (permalink)
Elyu's Avatar
Yes, i've got some problems with the "windows", sometimes the"wall" didn't do the hole by himself.There's only this problem. good luck :)
Old 04-12-2007, 02:58 AM   #5 (permalink)
redzuan3828
Guest
How you solve it????
Old 04-12-2007, 07:04 AM   #6 (permalink)
Elyu's Avatar
I've used Boolean and cut. :)
