Old 02-10-2008, 04:42 PM   #1 (permalink)
Low-Poly Challenge Leader
Isdrasil's Avatar
Rep Power: 5 Isdrasil is on a distinguished road
Speed Modeling - Best Concept Model Speed Modeling - Best Concept Model Speed Modeling - Best Concept Model Speed Modeling - Best Concept Model
Total Awards: 4
Creating Grass
I have several projects where i want to use realistic looking grass (lawns, hills, etc.) in the scene. Only one thing, how do you create such things?? I've tried "Hair & Fur" but didn't have a good result yet. I use 3ds max by the way.
Can someone help me???? I'd really appreciate it!
Isdrasil is offline   Reply With Quote
Old 03-10-2010, 09:25 AM   #2 (permalink)
Rep Power: 0 audryste is on a distinguished road
google is the best helper do not ask people to google for you!
audryste is offline   Reply With Quote
Old 03-10-2010, 07:21 PM   #3 (permalink)
Isdrasil's Avatar
Total Awards: 4
hey smartass, don't you think I spent hours searching google?? And what would be the use of this forum if we can't ask questions about obstacles you encounter? Then this part of the forum could be wiped away, abandoned, forgotten. Dude, if you think google is god, what are you doin here then????
Old 03-14-2010, 07:16 AM   #4 (permalink)
Rep Power: 3 SpardaDante is on a distinguished road
Well There is a pretty good way by scattering normal polygons and then adding a texture with Opacity.
Atleast thats what I do.Good luck!
SpardaDante is offline   Reply With Quote
Old 03-14-2010, 07:53 AM   #5 (permalink)
Isdrasil's Avatar
Total Awards: 4
Could you show me something? I've tried it too, but wasn't too satisfied. I saw Vue uses the same technique, but then called ecosystem. I'm using that now and it gives good result
Old 03-14-2010, 10:00 AM   #6 (permalink)
Here's a perfect tutorial for making it.This method was used in the making of "It comes a time of death"
Grass Tutorials. 3Ds Max Tutorial
Old 03-14-2010, 09:23 PM   #7 (permalink)
Isdrasil's Avatar
Total Awards: 4
looks good! I'll give it a try. If i have renders, i'll share them.
Old 03-14-2010, 11:35 PM   #8 (permalink)
ochiana nicolae
the eye's Avatar
Rep Power: 5 the eye is on a distinguished road
Speed Modeling - Best Concept Model Speed Modeling - Best Traditional Model The Ultimate Skill Challenge (T.U.S.C.) 3D Scene Modeling Competition Low-Poly Modeling Award Speed Modeling - Best Traditional Model
Total Awards: 7
hi isdrasil. have you checked this evermotion tutorial? looks prety good.
Grass with 3ds max and V-Ray for flat grounds - Evermotion.org
or this ones :
3DS Max VRay Grass
Vray grass tutorial part 1 Peter Guthrie
vrabia malai viseaza si calicu' praznic.
the eye is offline   Reply With Quote
Old 03-15-2010, 12:28 AM   #9 (permalink)
Isdrasil's Avatar
Total Awards: 4
i know those tuts already, but thx! Only thing, i dont work with vray. Still want to dive into that renderer, as it is one of the greatest!
Old 03-27-2010, 01:54 PM   #10 (permalink)
Rep Power: 0 mohamedharsha is on a distinguished road
You can get the best result from 3dmax hair and fur,but the reality is depened upon the materials,lighting,shadows and environment settings.
1- use the omni light
2-go to light settings
3-slect inverse decay instead of none
4-select area shadow type
5-use bump map in material editor
this is the easiest and fastese way to getting reality to any things not only to grass
mohamedharsha is offline   Reply With Quote
Old 03-27-2010, 07:39 PM   #11 (permalink)
Isdrasil's Avatar
Total Awards: 4
maybe i wasn't so clear, but it is for scenes outside in daylight. How would a omni light represent the sunlight?
Old 04-02-2010, 01:06 PM   #12 (permalink)
Moshie's Avatar
Rep Power: 4 Moshie is on a distinguished road
Speed Modeling - Best Traditional Model Exclusive Publisher Speed Modeling - Best Traditional Model
Total Awards: 3
vray displacement map FTW :D its a great tool no doubt about it
this is if you have it?
also try modelling a few blades then attach them together then add them a proxy then scatter them across a plane I do this quite often gets different looks and effects also its fast.
i like to Model, Model
http://www.way2adv.com/ http://www.crgeary.com/
Moshie is offline   Reply With Quote
