Rep Power: 0 ![]() | For the max users. I have a lot of problems by adding a surface to my spline cage. If you have so this will sure help. When you'r spline cage is done (the vertixs made 3-4 side polygons) you add the surface modifier to the model an then.......My model lokes like a broken cloth. What i have do wrong. Nothing!!! I take the last chanse to finisht my model. All vertixs one at other fuse them and in the properties for surface make sure that the thershold is set to zero. This halp in every cases. |
| Registered User Join Date: Apr 2003
Rep Power: 0 ![]() | LInk If you understand french, you can read good tutorial on surface tool to this link: http://mr2k.3dvf.com/tutorials/max/tutorials.htm take time to look the Joan of Arc by Michel Roger, an excellent and complete tutorial (polygon modelling). you can find the translate at: http://www.3dtotal.com/ Good luck! |
| Spline Join Date: Apr 2003 Location: Quebec, Canada
Rep Power: 0 ![]() | spline hi! sometime you can hade just a vertex to a side of a triangle polygone if you have one in your modeling, no mather where you put it, it may correct your probleme. And me i alway try to make 4 side polygone, it make better modeling this way. You can play with the flip normal in your surface tool and the patch topology steps. I work with the version 5. Hope that help you my friend!!
__________________ With practice you become a Master. When youre the Master, start over and practice again. / Spline Last edited by Jean Simard; 04-12-2003 at 11:29 AM.. |
