| Forum Moderator ![]() Join Date: Aug 2003 Location: Serbia & Montenegro
Rep Power: 9 ![]() | Plugins can do amasing things. But, the problem is that it's sometimes hard to find them. It would be great if they all were on one place. So, everyone, put the links to download sites here! NOTES: (I'm just asking you to do the folowing, but you dont have to do it) 1) Please add a short description for each plugin. (And, if you realy heat to write descriptions: make them supershort :) ) 2) PLEASE don't write 'thank you' post to each other (unless you REALY, REALY want to), because they make links harder to find. I'll suggest that you write that stuff in the same posts where you've put your links. Here are some plugins from me. --------------------------------------------------------- >> (3ds max 4) Texporter http://www.cuneytozdas.com/software/...xporter3_4.zip Sometimes with Max's Unwrap UVW you can't get what you want. This plugin can create a bitmap that shows you the UVW map. You can use it later with Photoshop or some other program. E.g. you crete a human head and then you add cilindrical UVW map, then use the Texporter and than you can make your texture easy. Wery usefool plugin. --------------------------------------------------------- >> (3ds max 4, ?other) Dynoskin http://www.blur.com/Tech/zip/dynoskin.zip Dinosaur skin texture map. Nice plug. --------------------------------------------------------- >> (3ds max 4, ?other) HighlightOnly http://www.blur.com/Tech/zip/highlightonly.zip Generates only the highlight part of the shade equation - for use with shellac --------------------------------------------------------- >> (3ds max 4, ?other) Linear http://www.blur.com/Tech/zip/linear.zip Specialized 3d gradient --------------------------------------------------------- >> (3ds max 4, ?other) Dirt http://www.blur.com/Tech/zip/dirt.zip Dirt texture map, nice & usefool --------------------------------------------------------- For folowing 2 good plugins you need this: http://www.blur.com/Tech/zip/blurlib.zip --------------------------------------------------------- >> (max) BlurFire http://www.blur.com/Tech/zip/fire.zip Max's fire (or Combustion in < R4) is just not good enough. But there is this Great fire plugin. --------------------------------------------------------- >> (max) DustDevil http://www.blur.com/Tech/zip/dustdevil.zip Great for explosions and dust. Must try. --------------------------------------------------------- >> (max) Camoflage http://www.blur.com/Tech/zip/camo.zip a camoflage texture --------------------------------------------------------- >> (max) Electric http://www.blur.com/Tech/zip/electric.zip Uesefool tendrily noise texmap - now has exponential falloff --------------------------------------------------------- >> (max) LightBoy http://www.blur.com/Tech/zip/lightboy.zip manage scene lighting from a lightboard --------------------------------------------------------- Take a look at this link: http://www.cuneytozdas.com/software/ Here you can find: Brazil r/s QuickDirt Texporter Color Correct HDRI Input/Output Math MAX SIRDS / SIS Generator (stereogram plugin) Super Ellipsoid --------------------------------------------------------- & here are some GREAT plugins provided earlier by Stryker: (I'll see if I can find Illustrate! download link, but for now:) Illustrate! keygen: http://deep.sitenest.net/files/others/Illustrate!_5.10_build_1.zip Illustrate! is a Great toon-shade plugin ------------- ShagHair - creates hair & fur, but it can do much more http://www.3dm-mc.com/files/others/S...r1.01.15R4.zip ShagHair Keygen: http://deep.sitenest.net/files/other...-keygen-r4.zip ------------- Grass-O-Mattic - creates grass, but you could find alternative uses (max 4) http://www.3dm-mc.com/tutorials/grass/index.php?id=30 (mac 3.1) http://www.3dm-mc.com/tutorials/grass/index.php?id=29 ----------------------------------------------------------- Also see the stuf you can download from 3dm-mc.com site. |
Rep Power: 9 ![]() | Check this site, there are some cool plugins. http://dieticstuff.narod.ru AfterBurn is one of them. It's an exelent plugin that creates great volumentric particle effects ---> explosions, smoke, fog, dust, and much, much more! It's here: http://dieticstuff.narod.ru/afterburn.html |
Rep Power: 9 ![]() | get plugins from here lots of plugins here: www.maxplugins.de , here:www.3dcafe.com and here:max3d.3dluvr.com note:not all but even the most plugins for max R4 work with max R5. |
| Guest
| Max Plugins I think every max user should have these plugins: For Max 4 & 5: http://www.habware.at/duck4.htm For Max 6: http://www.habware.at/duck6.htm I use Max and Poser a lot, so the plugins to import and export OBJ files are indispensable for me! |
| | #8 (permalink) |
| Registered User Join Date: Jan 2004 Location: ohio Age: 20
Rep Power: 9 ![]() | ere is a quick way to get big plugins(since we are all talknig about keygens and all) Go to file www.filemirrors .com and use the search parameter "contain" with "3dsmax" as the file name. and no this is not a shareware site and you do not have to download any additional software. the speed is good. and you get links directly to the file. no queing what so ever. |
| 3Dmax--- sent from above | www.maxplugins.de there is alot of plugins for all 3dmax versions !!! :D Great:sm: |
