Go Back   Community for CG Artists > Main Forums > General Technology > Animation
Old 10-06-2007, 04:41 AM   #1 (permalink)
Rep Power: 0 TingOn is on a distinguished road
Unhappy Animation with vray...
Hi.
Please tell me how can i animate a scene with GI.
help me plz!!
TingOn is offline   Reply With Quote
Old 10-06-2007, 02:15 PM   #2 (permalink)
selvaimages's Avatar
Rep Power: 0 selvaimages is on a distinguished road
Smile
Originally Posted by TingOn
Hi.
help me plz!!
Hi, you have to calculate the irradiance first.
Select the v ray frame buffer - Tick 'enable bult in frame buffer' but don't tick 'the v ray raw image or in common rendering file out put'
Select the 'multiframe incremental' mode in the irradiance map,
Select 'save' give a name and save the irradiance map
Tick on "on render end - don't delete and also auto save.
The secondary gi engine should be quasi-monte carlo.
After calculating the irradance. when u start rendering - in the irradiance tab you should go to 'mode' again and select from 'file' and you select browse the file and give the same irradiance map file. save the output files. and give render.
selvaimages
selvaimages is offline   Reply With Quote
Old 10-06-2007, 04:46 PM   #3 (permalink)
Hi My friend.
Tnx for your usefull comment.
Nice to meet u.
at your job...
Old 12-17-2007, 10:36 PM   #4 (permalink)
Rep Power: 0 Ravi Kumar is on a distinguished road
Hi, I dont know what is 3D , so pls explian and send me vedio files of animation tutorials and also one rigged charactor.If you have any vedio files regards to basic compositing to highfy compositing in Digital Fusion....pls send me other wise pls suggest me other sites also ....Thank you my friend
Ravi Kumar is offline   Reply With Quote
Old 01-17-2008, 04:44 PM   #5 (permalink)
Rep Power: 0 100rabh is on a distinguished road
Searching for same...
anyhelp???
I am wt I am!!
Still no Pain!!
100rabh is offline   Reply With Quote
Old 03-02-2008, 07:44 AM   #6 (permalink)
Rep Power: 0 The drug's is on a distinguished road
how we can save time for render Vray animation
The drug's is offline   Reply With Quote
Old 07-23-2008, 03:36 AM   #7 (permalink)
Rep Power: 2 anthonyduo is on a distinguished road
Send a message via MSN to anthonyduo
Use a low Irradance setting, It's usually set to high, which is often more than is needed, I only use high if I'm making a picture or two. If I'm going to make an animation I'll use medium or something.
anthonyduo is offline   Reply With Quote
Old 07-31-2008, 06:53 PM   #8 (permalink)
Rep Power: 0 takeshi kawano is on a distinguished road
It seems that an author is a Japanese, but the contents of the blog are incoherent, but are interesting probably because they look. This author writes that I make interest only for the naruto-related article thoroughly. In addition, I understand an animated cartoon of naruto in Japan, comics circumstances well. It is the blog which it wants to support carelessly.
 In addition, I feel horror, surprisingly, to update it almost every day. I have registered myself with one highlight or bookmark.
(URL)naruto anime manga ray
takeshi kawano is offline   Reply With Quote
