Old 11-23-2009, 03:19 AM   #1 (permalink)
Rep Power: 0 hose pipe is on a distinguished road
Vue and Maya Integration
This tutorial provides extensive training on e-on Vue 7 xStream and Autodesk Maya 2009 integration. We will start off by first creating the environment inside of Vue taking advantage of its ability to create and render natural and realistic 3d environments and efficiently handling huge scenes with millions of polygons. Maya would be used for the job of animation and rendering overcoming the problems experienced during the not so seamless integration between the two softwares. This training kit also covers Maya dynamics to create exhaust flames, jet and missile trails etc that will be rendered out separately. The final render would then be imported inside of after effects for some tweaking and composting the different layers together to produce the final result as you can see.
ignisfatuus.in
hose pipe is offline   Reply With Quote
Old 11-17-2011, 02:54 AM   #2 (permalink)
Rep Power: 0 ahamg is on a distinguished road
need to
What do I need to build a render farm?
Maxprodata Infysource
ahamg is offline   Reply With Quote
Tags
after effects, dynamics, maya, tutorial, vue
