Old 05-19-2009, 11:51 PM   #1 (permalink)
Rep Power: 0 Cory is on a distinguished road
Snapping Verts question...
I'm just wondering how to snap all the vertex's on the side of an object, into a straight line at once (so it mirror's properly), instead of selecting one at a time then moving it. Is it even possible?
Thanks!
im also using maya 2008
Cory is offline   Reply With Quote
Old 06-04-2009, 02:39 AM   #2 (permalink)
Divide/Zero's Avatar
Rep Power: 4 Divide/Zero is on a distinguished road
select boarder using "select boarder edge tool" then scale all the way to the center of the manipulator tool, then using the move tool press X and snap to the center
or select all the verts using shift
Divide/Zero is offline   Reply With Quote
Old 06-09-2009, 01:02 PM   #3 (permalink)
Rep Power: 0 Controller is on a distinguished road
Hi Cory. you can try this:
Select all the vertices you want to move
Press W for move tool
Activate one axis by clickin (x,y,z) - it becomes yellow
locate one vertice that is already in position
Press V and middle mouse button click it (normally you have to wiggle the mouse to work)
- Now the selected vertices have the same position in the selected axis. if you want to be at the same position, like one on top of the other, all you have to do is not activate one axis, with that all the axis are active so it will snap in x,y AND z.
Tell me if you have any problems.
Controller is offline   Reply With Quote
