| Registered User Join Date: Aug 2006 Location: Kolkata - India Age: 35
Rep Power: 0 ![]() | Hi , Just wanted to know .... how can we have a twist / spin effect on each particle in Maya . If it is through expressions, then what is that expression I can use ?? Can someone help ?? Regards Amlan70 |
| Guest
| hi, try to use the turbulence or vortex fields with the particles... select the particle then, on dynamics menu go to "fields" -> and there you have some... i think you should see all... give more frames (at the bottom) and hit play to see the effect. |
| Moderator Join Date: Feb 2008
Rep Power: 0 ![]() | Changin directions You can also try to use keys, and on every differen key change direction of particles ( if you are using Direction instead Omni ). For short scene it can help. Enjoy |
